I have windows xp I bought an embroidery machine. It came with a usb cord, but my computer want reconise it . What should I do?
    Scholar:
  • 81 Answers
For this your usb machine must have some drivers disk , please insert the driver disk and follow the instructions and when it ask you to connect the device then only connect the device , it should work ,
if still dosent work then click on start the select run in run box type devmgmt.msc and hit enter it will take you to device management window , once you reach there on right hand side of the window you will find the devices listed at the bottom of the list you will find unioversal serial bus controller click on the plus sign next to it it will populate list check for usb root hub select each root hub and uninstall all of them mind you you should not touch sis open host controllers , just uninstall usb root hubs , once done restart the computer and try connecting it , it should recognise the device .
************please also check for device compatability with windwos xp before performing any of the steps ***************
thanks
if you like my solution please rate the solution.
Posted on Sep 04, 2010
I have a 3D/ Pfaff 2170 Creative & I'm using Windows XP. No device found error. I can not transfer the embroidery design to 2170 Pfaff. Help!
Sounds like you don't have the device driver on you computer for the sewing machine. Question: Did it ever work? If it used to work but doesn't now, try using a different cable from the computer to the sewing machine. You can also try rebooting the computer (with the sewing machine connected and powered up) to see if it will locate the machine.
Dec 19, 2014 | PfaFF Sewing Machines
How can I send designs from my PC to my Toyota 830 embroidery machine when my Pantograms software/hardware is no longer working?
Some of the Pantograms software programs require a USB dongle connected to the computer. However, the driver for this dongle has to be installed before you install the software or connect the dongle. I suspect you may not have installed the driver or the dongle is missing.
Assuming that the dongle is connected:
Close your embroidery software program and all of the Pantograms software, including the Network C software, on your computer and remove the USB device. Put the software install CD into your machine's optical drive. (If your new machine doesn't have an optical drive, get a USB optical drive or copy the files from the CD to a 1GB+ USB flash drive at another computer with an optical drive.) If Windows XP starts the autorun routine for the CD, click Exit. Then double-left click on My Computer to launch File Explorer. Go to the CD drive (or USB drive if you used the work-around) and double-click on it. Open the Rainbow Drivers folder and then open the XP folder. Double click on the program: setup.exe . Choose Complete install as the program executes. Then close File Explorer when the install is done. Now insert the USB dongle and follow the on-screen message about New Hardware found to install the Rainbow driver from C: .
If you do not see the New Hardware found message, try putting the dongle into a different USB port. (Make sure to avoid USB hubs - they can add to USB device issues.) If the dongle doesn't work at any port, you may need to use a different method. There is a flash reader available for connecting a USB flash drive to the Toyota 830 here: http://www.plrelectronics.com/lab/usb_reader.php . (Scroll down to the Toyota machine section. This isn't cheap but it is cheaper than some of the newer embroidery software packages.)
I hope this helps.
Oct 26, 2014 | Sewing Machines
Transferring DVD designs to USB stick for my Husqvarna Designer 1
First you need your 4D software installed on your computer (or which ever version you are using). Insert the DVD into your drive. Then open your embroidery program and then click File and Open. When the new window opens, search for your DVD drive then find the embroidery you want and click Open. The embroidery yoiu chose should open in your embroidery program with the hoop displayed on the screen. Then save the embroidery under a new name in your embroidery design folder on your computer. Then insert your USB into your computer, Open Disk Manager and Read your USB. Then click on one of the empty squares and then click File then Open. In the new window find the embroidery file you saved under a new name on your computer and choose it. It should show up in the empty square you clicked on. Then Write to your USB. Now you are ready to move your USB to your machine and the embroidery should be there. Hope this helps. Good luck.
Oct 17, 2013 | Husqvarna Designer I
I have a Toyota 830 embroidery machine. I am getting RS232C Connect and Internal Communication error messages. I have the serial cable from the embroidery head connected to my Compaq PC using a Belkin...
if you have pantograms software I'd like to have you make a copy of it if it is ver 7.55 7.60. I'll pay you for doing it. My original copy isn't readable, and I have to reinstall it.
Thank you
.leedon@prolog.net
Aug 09, 2011 | Toyota Sewing Machines
I have a new windows 7 computer and want to use my white 4400 embroidery machine on it. How do I load a new driver for my machine?
Unfortunately, it seems that the company that bought the White brand (SVP) has no interest in creating new drivers for the machine. Is your computer running the 32-bit or the 64-bit version of Windows 7? (Start > Control Panel > System and Security > System. If you see x64, you have the 64-bit version.)
If you have the 32-bit version, you can try the compatibility mode. With the White USB drive connected to the computer, right click on the installer instead of normally running the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator. Then check if the program itself is running in the compatibility mode by right clicking again and choosing Properties.
A method that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software that came with the sewing machine in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS.
I hope this helps.
Apr 17, 2011 | White Sewing White 4400 Computerized...
Have a new computer with windows 7. my old husqvarna viking #1 sewing/embroidery machine software is downloaded, but unusable. Viking says to buy new software costing at minimum $500.00 The message I...
You will have to maintain an XP computer or buy new software there is no fix for your problem.It's the electronic age the old software was written for the XP operating system.When MS changed the operating system Husqvarna Viking had to design new software it's that simple.Don't blame the manufacturer Microsoft made the changes that created the problem. www.sewvac.com
Jan 28, 2011 | Husqvarna Viking 1
I have a Husqvarna 1250/Viking 1+ that my aunt recently gave me when she upgraded machines. I have installed the Customizing 95 (version 1.31) software on my laptop and it works fine. However, I can not...
1. Did the software come with a dongle? This is a "key" that looks like a memory stick, that is actually a copyright protection device. You cannot access the program without it. To get the program to recognize it. plug it into a free USB Port, then power up your computer. It will read the dongle as a new device and install it on your computer. Always make sure the dongle is plugged into the same USB port as when its installation.
2. Check the operating system compatibility of your embroidery software and your computer.
What is your computer's OS? If you have Vista, it will not read Win95-XP. In that case, you may need to find a used computer to dedicate to your embroidery and install Win 98. I have XP 2000 and it reads all the Win programs back through 95.
My Husqvarna Rose/3D Embroidery Studio, will not operate with the Vista program. It will run on XP, because XP is backward compatible to previous Windows programs.
If this is the problem, you can still purchase older Windows programs very affordably. Before installing it on your hard drive, I would get expert instructions from a professional, who would back up your hard drive. I've also heard of people partitioning their hard drives, so that they could use more than one operating system.
(This is MUCH CHEAPER than purchasing a new machine and all the software, etc to go with.)
Just a note: The small notebooks they've come out with, do not have the proper drive to run your embroidery program.
3. If you have the reader'writer that came with the machine and no serial port on your computer or printer, you can take the box to your local Radio Shack or computer repair, where you can get an adapter with a serial plug on one end and a USB plug on the other, or get the "Ultimate Box Plus". The adapter is cheaper.
One, or all, of these little tidbits may fit your problem.
Hope this helps.
Aug 01, 2009 | Husqvarna Viking 1
Singer Quatra Futara 350
I know this sounds too easy, but I found that when I got that message, I had actually not turned the sewing machine on ... or the USB cable from the computer was not connected. Try saving your design under File ... Save as .... into a folder where you know you can find it ( or on the desktop ), then turn the sewing machine off, back on, and reboot the computer software.
guglermusic
Apr 22, 2009 | Singer CE-200 Quantum Futura Computerized...
Futura CE 150
There may be a small "DRIVER" needed for the computer to "see" the sewing machine (*make sure machine is turned on!) when the cable is hooked up. (*could be a bad cable try another they are $2 at fry's) This sometimes requires more computer work to make sure the usb cable is connecting the embroidery machine to the computer correctly.
This driver may be located on your Singer Futura Disk? this is not your program to run the singer machine but the one to connect the two so they can communicate embroidery designs and such.
Deep breaths it will never work if it goes out any window.
Cheers,
Embroidery Services
San Diego, CA
Sep 17, 2017 | Singer CE-200 Quantum Futura Computerized...
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
