Question about Nikon COOLPIX P4 Digital Camera
Will not power on
Did not solve problem, will nee assistance with checking camera button
  • 3,037 Answers
Alright, first you need to remove the outer panel, you should find some screws on the outside to remove, and then it should pop off (this may take a little force but as long as all of the screws are out, you should be fine)
then you should be able to find the wires and the on/off button and check it to make sure there is nothing loose or broken.
Another thing I suggest before doing this, is again, removing the batteries, the memory card and then switching the mode it is in and see if it will start, if not, then start taking it apart. good luck
Posted on May 12, 2008
PV GS9
replace a new battery ......because the battery has to supply power to display , flash ,motor etc..........
Jun 23, 2008 | Panasonic Palmcorder PV-GS9 Mini DV...
Hard reset could not been done
the hard reset should reset it, let me check the process.
Jun 23, 2008 | Siemens SX66
Sony Cyber-shot DSC-T7. Pressing Menu button does not access any menu. Can only access Image Size menu by pressing Image Size/Delete button.
I'm sorry that the Menu button on the Camera is not working. Please try a power resetting and check the operation:
To perform the power resetting, remove the battery, press and hold the power button for more than 5 seconds and then reinsert the battery.
If the issue persists after resetting, service may be required. Please click hear to locate your nearest service facility.
Thanks for understanding. Please let me know if you require further assistance.
Jun 19, 2011 | Sony DSC-T7 Digital Camera
I nee to syn this router with my cpu. what do i do.
Belkin reset:
1. Locate the reset hole on the router. The button will be on the back or side of the router.
Leave the router powered on.
  1. Use a paperclip (or similar) to press and hold in the reset button for 10 seconds.
  1. Remove the paperclip.
4. Wait approximately one minute for the router to restart.
The settings for the router have now been reset back to their default.
Then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jun 12, 2011 | Belkin F5D8236-4 Router
Camera turns off when taking picture
Try changing the battery brand and see if this helps..I seem to have the same issue with my camera with certain battery brands..Solved my problem by switching brands..
Jun 21, 2008 | Fuji FinePix A345 Digital Camera
How do in remove a contact from the reject list in a samsung gt-b5722
Hello
The link below should be of help.
Click HERE to navigate.
Feel free to let me know if you nee any further assistance.
Kind regards
Andrea
Nov 15, 2010 | Empire TechCell TCSBLSM80 8MM SAMSUNG174...
Will only take pictures....won't let me use video, picture editor, games or access memory.
HI,
Here are some steps to solve your issue:
1. Press the Reset Button with a paper clip. This should reset your camera and should wok fine..
If this does not solve the problem, please continue the following steps:
1. Please make sure the camera is OFF.
2. Interrupt the power supply by removing the batteries.
3. Let the camera sit for a few minutes without batteries, then replace the batteries and press the Reset Button again.
4. Turn the unit ON. The unit should now be ready to play again.
5. If the unit still does not work, replace the batteries with an entire set of new batteries.
Please leave me comment, if you need further assistance
RNJ VINODKUMAR
Oct 06, 2009 | Vtech Kidizoom Digital Camera
Error message camera is unplugged when installing
u nee dto dl updates or updated verison from website try that 1st ok
Jan 06, 2008 | Logitech Quickcam IM 961361-0403 Webcam
Troubling uploading pictures
please chek the button on camera stand taht must be on and second camera must be in USb stream mode. all you nee dto change the setting no technical problem. also you nee dto chek for USB driver whether it is installed . if it is installed when you connect cable the computer give new device found message. r u getting that? let em knwo Thanks Sangita
Apr 23, 2007 | Canon PowerShot A75 Digital Camera
Nikon COOLPIX P4 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
