Question about HP Pavilion ze2000 Notebook
I have a Pavilion ze2000 laptop. The monitor has an approx. 2" wide line down the screen. You can see the display through it but over time the line has been getting darker. Does this require a new monitor?
  • 540 Answers
Yes unfortunately replacing the screen will be good idea because the screen is defective and it can not be repaired
Posted on Sep 04, 2010
My laptop has black screen?
Please connect the VGA connector which is a 15 pin blue connector in your laptop with an external LCD or monitor. If you see the display on external device your laptop screen needs to be replaced
Thanks
Jun 15, 2012 | HP Pavilion ze2000 Notebook
Not able to start up my hp dv4-1124nr laptop. Giving me black screen all the time. Have tried options like removing battery, AC Adaptor and also memory modules. It is still showing black screen after...
Try hooking up an external monitor. If the external monitor is working and showing you what you are used to seeing, than you just need to switch the laptop back to it's regular display mode.
There is a key that looks like this
'o'
you need to press the function key and this key (usually f4) at the same time to switch displays.
Dec 12, 2010 | HP Pavilion ze2000 Notebook
I have a 2inch wide band down middle of screen on
1) Have you installed new drivers or software or drivers? If so, remove them and restart the computer.
2) Try applying pressure with your fingers on top of the screen. If the band dissapears or dimishes, you may have a broken screen and it will need to be replaced.
Mar 19, 2010 | HP Pavilion zd8000 Notebook
I have an hp ze2000. I hooked it up to an external monitor. When I unhooked it and restarted it my laptop screen now stays blank. Who knows the answer to this?
I think you have to reset through setup F12 or is it F8 restart and push one or the other, then locate menu for screen click to enable.
Haven't come across this before. Best I can suggest?
Nov 16, 2009 | HP Pavilion ze2000 Notebook
Vertical lines approx 2"wide appear on screen and remain after re
Your lcd is going out. Either that or your video card.
You can verify this by hooking up an external monitor to your laptop. If you see lines or distortion on the external it's the video card ( GPU ).
If you don't, it's probably the lcd.
90% of the time it's the lcd.
Easiest and cheapest way to fix it is to purchase an lcd from ebay and then just swap them.
Let me know if you need any more help.
Best of luck!
Mar 02, 2009 | HP Pavilion zd8000 Notebook
Hp Pavilion ze2000
this is a very common problem if you always hav your llaptop on then its basically fried into your screen. if not and u damaged it somehow then you need a replacement. and if none of thats the case your monitor got 2 overheated or maybe one of your lcd cords coming from the mother board(hard drive) of your laptop is loose or damaged by heat
Dec 01, 2008 | Computers & Internet
Screen problem
Sure, To find out if it is a Display issue or not,
you can connect an external Monitor to the Notebook.
If you see similar display issues then The issue may be fixable otherwise you will have to Replace the Display of your Notebook.
Jul 17, 2008 | HP Pavilion ze2000 Notebook
Screen goes awire?
sounds like a backlight or display power problem.
Oct 24, 2007 | HP Pavilion ze2000 Notebook
HP Pavilion ze2000 Notebook Logo
47 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
