Question about Samsung SCX 4521F All-In-One Laser Printer
Cant lift the paper from the tray for printing
  • 360 Answers
Hello clean your paper feeding roller or replace it
Posted on Sep 06, 2010
What corrective action for a 'no paper, add paper' message?
Please take out the paper cassette tray and see if there is a paper sensor hanging down underneath the machine. Also check to see if the paper cassette tray is lifting up. The tray should make a noise when lifting up. Check to see that the printer recognizes the correct paper size.
Jul 09, 2015 | Dell 2155cdn All-In-One Laser Printer
My MFC8460N Brother won't print. It makes this
Gears on the tray is broken, or the gears that lift the tray. (thus the clicking noise). And the no paper is due to the actuators underneath not being activated because of the non lift.
Feb 12, 2010 | Brother MFC-8460N All-In-One Printer
Hp laserjet 8150. i have a problem, tray 3 empty, always but have paper in tray 3
CAUSE: This error message indicates the paper present sensor flag in one of the trays does not detect paper in the tray. This could be caused by one of the following:
  • A broken sensor flag
  • The tray paper guides being set too close and restricting the paper from being pulled
  • The tray is not lifting
SOLUTION: Follow the steps below to determine the cause of a false TRAY X EMPTY message. Tray 2 empty
  1. Verify there is paper in the tray.
  2. Open the duplex unit access door just above Tray 2 on the front of the printer.
  3. Check the black-paper present flag by looking in through the duplex access door.
  4. Open and close Tray 2 and observe the tray lifting looking through the duplex unit access door.
The tray lifts but the error is still present
  1. Inspect the paper present flag on the PIU located just behind the pickup rollers. Ensure the flags are present and not damaged.
  2. Remove the tray guides from the tray and reseat them. Ensure the guides are seated correctly and are in the correct slot for the size paper in the tray. Add paper to the tray and try printing again.
  3. Try another known good tray, if available.
The tray does not lift and the error is still present
  1. Remove the tray, remove the paper in the tray, and inspect the lifting plate in the tray for damage. Ensure it will lift freely by hand.
  2. Try another known good tray if available.
Tray 3 empty
  2. Remove Tray 2.
  3. Open and close Tray 3 and verify it lifts by observing through the Tray 2 cavity.
  3. Try another known good tray if available.
Tray 4 empty
  2. Open Tray 4 and check for an extra **** of paper stored on the left side of the tray. This can cause the tray to stall while lifting and result in a tray empty message.
  3. Defeat the interlock in the vertical transfer unit (VTU). Open and close Tray 4 and watch the tray lift through the VTU door on the lower-right side of the printer.
    NOTE: Follow troubleshooting steps for Trays 2 and 3 when working with the 2 X 500 sheet-input tray.
  1. Check the tray guides to ensure the guides are seated corrected and are in the correct slots for the paper size in the tray.
  2. Inspect the paper present sensor for damage.
  3. Check for any broken plastic pieces in the tray that may be a broken sensor flag.
The tray does not lift and the error is still present Defeat the VTU interlock on the right side of Tray 4. Open and close Tray 4 and observe the tray lifting.
Nov 25, 2009 | HP LaserJet 8150n Printer
How do I load paper to print?
Hi mattside92
1) If the paper support flap is open, close it, and then pull the paper tray completely out of the machine. Lift the output paper tray cover.
2) Press and slide the paper side guides (1) and paper length guide (2) to fit the paper size.
3) Fan the stack of paper well to avoid paper jams and misfeeds.
4) Gently put the paper into the paper tray print side down and top edge first. Check that the paper is flat in the tray.
5) Gently adjust the paper side guides with both hands to the paper.
Make sure the paper side guides touch the sides of the paper.
Note
When you use Legal size paper, press
and hold the universal guide release
button as you slide out the front of the
paper tray.
Note
Be careful that you do not push the paper
in too far; it may lift at the back of the tray
and cause feed problems.
6) Close the output paper tray cover.
7) Slowly push the paper tray completely into the machine.
8) While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap
Good Luck, and don't forget to leave a rating
Thanks
Mark
Sep 29, 2009 | Brother MFC-440CN InkJet Printer
60.40 tray lifting error
lifting error should be describing the part of the paper tray or paper feeding mechanism that physically lifts the paper up in the tray to be fed into the print engine.
does this happen from all trays? describe your jamming if any.
Apr 29, 2009 | Office Equipment & Supplies
Cannot see a paper jam even when the messages say there is a Medi
The paper tray should lift to present the paper to the feed assembly. If the paper tray does not lift then that will require attention and a fairly extensive strip down to replace either the complete tray or just the lift assembly.
Apr 12, 2009 | Konica Minolta magicolor 2300DL Laser...
Kodak PD6000 Printer Dock will not lift and feed paper from paper tray
Greetings,
Here's the link for your products Troubleshooting Guide
Keep us posted and thank you for using our service.
FixYa - Technical Support, Instructions & Repair Service
Jul 30, 2008 | Office Equipment & Supplies
No Paper Light wont go out
is this still a current issue?
Jul 22, 2008 | Brother MFC-8860DN Printer
NO paper light
Something worth considering: Check that there is enough slack in the paper tray to allow the gears at the front to lift the paper to the pickup wheel. I've found that on my firm's 8860DN, the paper tray being set too "tight" can cause too much friction, preventing it from moving. If you can raise/lower it by hand (using the gears on the side of the tray), you should be fine.
Dec 04, 2007 | Brother MFC-8860DN Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
63 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
