Question about Simpson Garden
I have a simpson 3000 belt drive w/ a honda moter.runs great and well taken care of. delivers good pressure, but when not holding the trigger a small burst of air/water shoots out from thehigh pressure overload about every 15 sec. i changed the springs on the system and it checked out o.k. is there an adjustment on the bottom of this overload valve? please return a.s.a.p. Thanks, Pettke deco. Raymond
  • 2 more comments
  • fauxray Sep 05, 2010
    Thanks but I need to know how to fix this...I know what the problem is as you described but this is not helping me with the problem. Can water be heating past safety limits within 15 seconds? There is a screw on the bottom of this unit does this suggest an adjustment can be made? Thank-you
    This is an addendum to last message. The specific part on this pressure washer is a unloader valve UV760 series. Please refer to a manual to see what I'm talking about
    Thank-you
  • fauxray Sep 10, 2010
    ok,the effective part i am refering to is the unloader valve,on a simpson 3000 washer,uv760 series if that helps.when under pressure,[trigger on washer not engaged],water shoots out @the unloader valve every 10 to 15 sec and reacts like i am starting to pull the trigger;[moter under load.i had referred to the high press overload but that is not where the water is coming from.can i rebuild or replace the unloader valve if this is the problem,andif so how do i detect what unit to replace it with?
    sorry about my terminology
    thanks R.
  • Doug Gobeille Oct 21, 2012
    Some washers do have a high pressure relief...a lot like the thermal relief that J Trevino speaks of, but either way, your problem is that the "unloader valve", is not unloading properly. This Simpson unloader was a rare OEM piece only made by the original Simpson Co. switch is no longer in business. I saw a replacement New old stock on line for $400 dollars. Several differant manufacturers make similar and wholely adequate replacements that will U-Bolt to the same spot. General Pump and Giant Pump come to mind. Grainger, Northern Tool, Watercannon all sell this part. Match the pressure, the Gallon per minute, and the size and position of the inlet, the bypass, and the outlet for the easiest installation. Call 513-242-4500 if you would like futher help. Midwest Spray
    President:
  • Simpson Master
  • 1,383 Answers
I worked at a tool rental store during my college days and rented a similar unit quite often. I am puzzled about the high pressure valve that you describe. If I recall correctly, the units that we rented had a high temp relief valve. The springs were obtained in temperature incriments. Most likely water is heating past safety limits and releasing to allow fresh cooler water to enter loop. Do not leave the unit on bypass too long because water is looping thru unloader and heating up with every pass. Good Luck with your projects.
Posted on Sep 04, 2010
  • John Trevino Sep 07, 2010
    At the rental store, the pressure washers would get very high usage compared to yours for example, thus would get several years of use in very short time period. The mechanic was constantly replacing unloaders and thermal /pressure valves. The pressure /thermal valve has a seat that would be cut just like faucet seat. The valve is adjusted just a bit higher than unloader setting to help protect unloader. Best to lower pressure of unit to maybe 75-80 percent of max to preserve life of parts. Look here for universal eplacement parts, not expensive: http://www.pressure-washer-parts.com/pre...
    If water was released due to high temp limit, you would see steam or just measure water temp and compare to temp marked on valve. If your valve has adjustment I would not increase pressure, but instead lower pressure of unit at regulator to temp solve problem.
Unloaded valve not working properly
ensure that you do not have any leak not one drop coming from the output of pump to the end of nozzle not one drop after releasing trigger if so replace leak these unloader valves rely on trap pressure if pressure not trap she will cycle over and over.
Aug 16, 2013 | Simpson MegaShot 3000 PSI Direct Drive...
I have a simpson G3000 pressure washer. The small high pressure line from the pump has developed a leak, (it's about 18"s) Do you have a part number I could use to get a replacement, or point me...
You can use a universal hose for replacement. This hose should not be under high pressure (usually inlet water hose pressure). This is a bypass that is used when you release the trigger to wand. Look closely at the brass fittings of the hose, sometimes they can be reused by removing the clamp and cutting off the rubber part. Use automotive rubber hose (suitable for hot water system/radiator )or black pressure hose from Lowes (sold bulk) that will fit snugly on the barb and use simple clamps. You can make new hose by buying barbs and hose from Lowes or hardware/plumbing store. Good luck
Sep 13, 2011 | Simpson PS3200 Powershot 3200 Psi Direct...
I bought a honda pressure washer power boss 3000. I load the gasoline, start the machine, but pressure water is not coming out from the trigger. i tried so many things , but can t get started.
If you are using a water tank for water supply, remove the water supply line from the pressure washer and connect a water hose from a faucet. Turn the water on, then crank the engine. Pull the trigger of the spray gun until water comes out. When then water starts to spray properly the release the trigger, shut engine down with pressure on the line then reconnect the water supply from the tank to the pressure washer. If this fixes the problem then the problem was "air-locked"! Happens alot with new pressure washers that have never been run. If you need any other help, please email me @ davidandlisacampbell@yahoo.com
Feb 18, 2011 | Honda Pressure Washer PSI 3000
I am trying to disconnect the lower hose on this unit is a quick disconnect or does it screw off
If it is the trigger hose, more than likely it will screw off. You may need to squeeze the trigger to release the pressure in the hose. Then it should screw off.
Jan 28, 2011 | Simpson PS3200 Powershot 3200 Psi Direct...
NO PRessure
Hi It sounds to me like your unloader valve is stuck, this is the thing that is meant to move up and down when pressing the trigger.Please remove the unloader valve assembly and check for damage. If no damage is found then grease and lubricate this part and replace and this should work ok again.
Jun 15, 2010 | Honda Pressure Washer PSI 3000
2005 5.3 vortec top in no oil pres just got truck good moter or bad moter
have to see if the oil pump strainer is clooged...oil ports clogged??? was the motor taken care of...valve covers loaded up with sludge??? pan comes off the rest is to be looked at...if she was run on no oil pressure I sure would be suspect of this motor being in poor condition. Does it run???? Is it knocking?smoking? banging or clunking? if not put a gauge on the oil pressure sending unit hole and see if it really has no oil pressure or perhaps it has a bad sender?
May 06, 2010 | Chevrolet 1500 Cars & Trucks
No water pressure. feels like it is developing pressure in the pump but wont deliver more than a small stream and then enging cuts out like it is bogging down
Sounds like it could be just a main jet bloked in your lance. Please remove the jet and see if you have a good water flow when pressing the trigger.
Feb 02, 2010 | Honda Maxus Prosumer MX5223 Pressure...
97 accord 4 cyl shuts down at 3000 rpm
run engine codes, had same issue once before it was bad computer good luck
Jul 06, 2009 | 1992 Honda Accord
I have a 3000 PSI Honda pressure washer. The motor
May have sediment buildup in the pump housing, ???
Jun 04, 2009 | Honda Pressure Washer PSI 3000
Garden Logo
1,188 people viewed this question
Top Simpson Garden Experts
John Trevino
JOHN LAPIER
ray gallant
Are you a Simpson Garden Expert? Answer questions, earn points and help others
