Question about Dometic Rooftop RV Air Conditioner
The compressor will not turn off. - Dometic Rooftop RV Air Conditioner
  • 24 Answers
The relay (concator) that controles the compressor cycle is stuck closed need to replace it.
Posted on Sep 04, 2010
My 2002chevy trailblazer dies when I turn on the a/c why?
It is possible that the A/C compressor is locked up and when the compressor clutch engages it stalls the engine. With the engine off, use your hand and attempt to turn the compressor shaft manually. You can do this because with the clutch disengaged, the outer pulley that the belt runs on is not connected to the center shaft of the compressor. Turn the inner portion of the compressor, not the outer ring where the belt is fastened. You can see what I am talking about if you examine the A/C compressor with the engine running and the A/C turned off. You will see that the belt is turning the outer section of the compressor, but the center shaft is not rotating. You should be able to turn the compressor manually, though it may be rather hard to do, If you cannot turn it by any means possible, then you have a bad A/C compressor and should replace it.
Sep 16, 2014 | Office Equipment & Supplies
My access don't work I the ac compressor dnt turn
the compressor protected by a pressure switch it only turn on the compressor if there is a pressure on the system if no pressure it means there a leak on the system try to check
Jun 17, 2013 | Cars & Trucks
COMPRESSOR WONT STAY ON
You replaced the compressor? Sea Breeze
May 30, 2013 | Refrigerators
Is the switch that turns on cooling fans the same switch that turns on the air compressor i just replaced compressor and other parts and had it vacumed out ,oiled and recharged . and compressor wont
possible you have a bad low or high pressure switch on a/c system bad causing compressor not to engage, find switchs and jump across wires and see if compressor engages
Sep 03, 2012 | Kia Cars & Trucks
A/c compressor not turning on, freon level ok, no power to compressor
Hot wire the compressor from battery and see if it turns on. If it does then there is fault in AC switch/relay/wires. If the compressor still not running then compressor coil is gone, fortunately it can be replaced easily and you need not change the whole compressor.
May 07, 2011 | 2005 BMW X5
Warm AIR comes out WHEN AC UNIT is on i just
Possible Low on Freon, Bad Compressor Clutchhead, Blown hose, which in turn let all the freon out. Manually power up the single wire going to the compressor with the car running and see if the compressor clutch head turns on. If so Odds are the compressor is good. Check all hoses and compressor for buildup of oil which would be assumed as a leak.
Aug 31, 2010 | 2002 Mercury Sable
AC Compressor will not engage.
Inner rim is the compressor. If it wont turn youre compressor is bad.
Apr 16, 2010 | 2000 Saturn L-Series
03 Chevy Tahoe stalls out while taking a slow
have the a/c compressor checked, the a/c compressor might be locking up due to wear and bad bearings. one way to test is to try turning the compressor clutch while the ENGINE IS OFF, if the clutch is very hard to turn or won't turn at all by hand then the compressor is bad. the clutch is what turns the pully, the pully should spin freely, the compressor clutch is on the end of the compressor on the pully side.
Aug 16, 2009 | 2001 Chevrolet Tahoe
Won't cool any more
What do you mean turns on. The light inside is on. Do you hear the compressor coming on. If you hear the compressor turning on and the fridge doesn't get cold, compressor might need freon. If compressor doesn't turn on, your timer is not working
Jul 23, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Toyota Camry 95 V6 XLE Compressor
THE A.C COMPRESSOR BELT ALSO RUNS THE ALTERNATOR.AS OF YET THERE IS NO PULLEY U CAN INSTALL TO BYPASS THE A.C COMPRESSOR.SO YES YOUR A/C COMPRESSOR MUST TURN IN ORDER FOR THE ALTERNATOR BELT TO TURN.CALL AND A COUPLE OF ESTIMATES
Apr 29, 2009 | 1994 Toyota Camry
Dometic Rooftop RV Air Conditioner Logo
374 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
