Question about Bosch Axxis WFL 2060 Front Load Washer
Error code E-27 - Bosch Axxis WFL 2060 Front Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error E27 in your bosch washer means that the door switch has gone bad and to resolve this issue you’ll have to replace the door switch assembly. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 04, 2010
Self cleaning mode towards the end of its cycle went into a failure code cleared it by flipping breaker. Now when I run bake/convection it runs broil at 600. Lower oven now run under temp.
Amazon.com: Frigidaire Gallery 27 In. Stainless Steel ...
www.amazon.com/Frigidaire-Gallery.../B002HMRIBI
Amazon.com, Inc.
Rating: 4 - ‎4 reviews
When your appliance is delivered it will be brought into your room of choice and all ...The Frigidaire FGET2765KF Gallery Series 27 In. Double Electric Wall Oven, ... Using the "Quick" Pre-heat function on this oven, the timer goes off ... Great, until you check the temperature and find that it's only reached 225 degrees.
Frigidaire FGET2745KF Gallery 27 Double Ele
Frigidaire Model FPDS3085KA getting error code F90 ...www.shopyourway.com > Manage My Life > QuestionsMy wife did start the self cleaning and cancelled it and we have not been able to ...Frigidaire Model FPDS3085KA getting error code F90 ... I have tried holding the lock button down for 3 seconds and that puts it into a mode where it looks like it ...Missing: fget2765kfFrigidaire Range Error Codes for Self-Cleaning Rangeswww.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-range-e...Find error codes for your Frigidaire self-cleaning range at Sears PartsDirect. ...should only occur when the oven is active or when you attempt to enter a mode.Missing: fget2765kfFrigidaire Self-Cleaning Wall Oven Error Codes ' Sears ...www.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-wall-ov...
Jan 03, 2016 | Frigidaire FGET2765KF
Philips tv error codes 12 for 42pfl3603d/27
Power supply problem. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 30, 2014 | Televison & Video
Error 27
Precor Error 27, Too Much Drive Motor Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 27
Feb 18, 2014 | Precor 933 Premium Series Treadmill
I have a 300 Series Bosch front load washing machine witn an E:27 error message. I can't get it to reset. What is wrong?
Do you know what the E:27 error code means? Different machines have different codes. I am not a bosch expert, but if you provide the complete model # to your machine chances are good that i can find the meaning of that error code and maybe a whole lot more.
Jan 06, 2013 | Bosch Washing Machines
Error Code 27 for 1994 Jeep
adding If you are getting correct pulses to the injectors, you can try 3oz of acetone and 1oz of marvel oil to each 10 gal of gas your fuel for the next few fill-ups...this will safely clean injector nozzles, providing they aren't worn out or internally binding.Your injectors are triggered by the computer, so check the plugs and wiring to make sure nothing is loose or shorting. There is much more to this, but it's a good place to begin.
May 30, 2009 | 1994 Jeep Grand Cherokee
Error Code E07-27 How can I fix it myself ???
That error is a finisher tray lift error. If you do not see anything binding the trays, service will have to be called or finisher disconnected. Pay attention to the screws, they can loosen causing the trays to bind.
May 11, 2009 | Panasonic Workio DP-3520 Copier
Error code 27
HI, Go to this site is has all fault codes all you do is find your product click it and it will show you the fault codes and what they mean and suggest how to fix it. http://www.repairclinic.com/0078.asp
Jun 08, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Error code thompson 32ws23u icc17 chassis
the unit is being over powered, by a faild component on the power board, i would suggest getting a new TV as replacong the LOPT does add up
Dec 09, 2007 | Televison & Video
Bosch Axxis WFL 2060 Front Load Washer Logo
230 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
