Seeburg Jukebox model PFEAIU manual & diagrams
5 Suggested Answers
  • 38 Answers
SOURCE: seeburg entertainer
THESE MANUALS ARE FOR PROFESSIONAL REPAIRMEN. YOU WILL NOT UNDER STAND THE LINGO. THE PROBLEM IS ON THE TORMAT UNIT. THERE ARE 4 WIRES ON THE BOTTOM OF THAT TORMAT UNIT. (FIRST POSSIBILITY) ONE OF THE FOUR HAS COME LOOSE. THE COLOR OF THESE WIRES ARE RED==GREEN== , AND TWO BLACK. MOVE WITH A LITE TOUCH. TO SEE WHAT ONE IS BROKEN. (SECOND POSSIBILITY) THE SAME WIRES GO TO THE REVERSING SWITCH. MOVE THESE WIRES WITH A LIGHT TOUCH.
DOCTOR FIX IT
E-MAIL SEYLEVITT@JUNO.COM
Posted on Jun 10, 2009
  • 38 Answers
SOURCE: seeburg jukebox sx 100 scans twice and returns
THIS JUKEBOX IS 40 YEARS OLD. LUBRICATION MAY BE THE PROBLEM. HERE IS HOW TO FORCE THE SEEBURG JUKEBOX TO PICK UP A RECORD AND PLAY A SONG.
LOOK AT THE ARM THAT HOLDS UP THE NEEDLE AND CARTAGE. NEAR THE MIDDLE OF THE RED ARM, ONE INCH TOWARD THE MOTOR, THERE IS A HORIZONTAL LEAVER LIFT IT UP A RECORD WILL GO INTO THE HEAD, THAT RECORD SHOULD PLAY THE SONG, IF THE LUBRICATION IS OK.
IF THE RECORD GOES INTO THE HEAD, AND THEN PUTS THE RECORD BACK IN THE RACK. YOU HAVE A LUBRICATION PROBLEM.
THAT IS A TOUGHT MACHINE TO FIX IOF YOU ARE NOT FAMILIAR WITH IT.
DOCTOR FIX IT.
Posted on Nov 04, 2009
  • 567 Answers
SOURCE: my seeburg disc jukebox skips a lot
try going into service mode to find the problem could be different things also you could try cleaning the laser this is one of the easy options
Posted on May 08, 2010
buddylove
  • 17 Answers
SOURCE: I have a a seeburg
check all fuses..a recap of the machine would fix this issue if it was a suddon stop dead and nothing symptom racaping is a good idea just after you see it run no matter how poorly but it would be a mistake to recap the machine right now because you have a hard fault and recapping presents it's own problems..no.
check all fuses first if not the fuses check to see all of the plug in cables are plugged in wiggle all of the plugged in wires it's possible one of the wires (or more) have hardened and is causing a short or intermittant problem (wires tend to get more flexible when warm as oppossed to when they're cold and THIS may be the issue! if AFTER you've checked on those two things and neither of the items helped at all? then it's time to call a repair man.voltages in any electronic device can be lethal and unless you know your way around electronics I would NOT advise you to go ANY further than the two checks I've given you here. let us know how it turns out
Posted on Aug 23, 2012
Where can I hire a repairman to fix my Whirlitzer juke box?
go google and type in--- service agents for wurlitzer juke box ---
find and agent closest to you and call him on the phone
Dec 23, 2016 | Audio Players & Recorders
Jukebox manual
Many on eBay
http://www.ebay.com/itm/Original-Rockola-Jukebox-Model-488-Service-Manual-w-wiring-diagrams-/231244858100?pt=LH_DefaultDomain_0&hash=item35d74482f4 Original Rockola Jukebox Model 488 Service Manual wiring diagrams
Aug 05, 2014 | Collectibles Jukeboxes Book Rockola...
Jukebox seeburg scd-1a>1. turn on 2. select CD song 3. sound blares (50db) HIGH
hi I can put files of seeburg on a disc which includes amps,selectors,wall boxes,recivers,auto speed units
email me
Dec 15, 2013 | Computers & Internet
I have a LPC 480 Seeburg Jukebox that scans, pick up the record, the needle touches the record, then returns the record to the carriage without playing. What can I do?
Try reading this, basically the fault can be in the mech, the amp or trip switches.
http://www.flippers.com/Seeburg-trblshoot.html
Nov 28, 2010 | Audio Players & Recorders
Wailing sound when 1971 seeburg juke box is started
I amnot very familiar with Seeburgs but the trip switch activates at the end of the record playing and THAT mutes the amp. The amp should also be muted until the tone arm lands on the record. So I would suggest the problem is in the amp.
May 05, 2009 | Audio Players & Recorders
I have a 1971 seeburg firestar jukebox - the zero (0) does not seem to work when you punch in the 3 numbers for the selection - so none of my selections that have zero in it do not play - also I do not...
Same key that operates the locks on the sides unlocks the top, but top might be sticky. Push down on it.
Order keys if you don't have them. It's key F291. GOOD locksmith can make it or order one off eBay.
Your jukebox is a USC2. Use that model number as a reference.
Keypad "0" contacts are probably dirty or broken, or the connectors to the keyboard or black and gray boxes might be loose or need cleaning. Circuit board might be dirty (YES! This is a common Seeburg issue). To clean it of check for broken contacts on the "0" key, you'll have to remove it and open it up. Putting it back together can be tricky. Be patient.
Worst case, you can install a replacement keyboard.
If you have someone come out, be SURE to have them give the jukebox a good lubrication. Seeburgs are complicated machines and need periodic lubrication.
Also, buy a manual. Jukebox repairmen don't usually have the manuals for your jukebox. Too many.
Mar 07, 2009 | Audio Players & Recorders
176 people viewed this question
 Grubhead
Grubhead
