Viking DFUD04 Built-in Dishwasher
Problem for Viking DFUD04 Built-in Dishwasher
Viking Dishwasher Leaks Into Base
By FixThisYa on May 12, 2008
What do you think is the most likely cause of this leak? I have a Viking DFUD042 (aka ASKO) dishwasher. Water leaks into the base. I've removed front plate, and removed water from base. This temporarily solved the problem and I was able to restart the dishwasher cycle. After a very short period, however (about 1 minute or so) the pump was the only thing working again, and it will not stop as long as its plugged in. (I'm assuming the base flooded again but did not pull the plate yet). The dishwasher does not appear (to me) to have a float valve. Am I right? If not, where is it, and how can I test/fix it? Also, I tried to take the back plate off by removing 4 screws. It would not come off. If I need to remove it, are there any tricks to removing it?
Solution #1
posted on Jul 27, 2008
Not Rated)
jmail
Rank: Apprentice
Rating: 0%, 0 votes
Since this was posted in May I guess it's been fixed but for those of you seeing this problem for the first time, here's one reply:
This sounds exactly like the problem I just found with my DFUD042. There is a small black hose between the base of the tub and a pump motor - part number on the hose is 8072888. The hose has a small **** or crack in it and water is leaking which is most likely the problem causing the symptoms. I had to throw the circuit breaker to get mine to shut off as well.
When I tried to remove the plate it was stuck under the black sound proofing so I had to work around it a bit until it finally came off. Now I just have to find the hose and some clamps.
Was this helpful?
Yes
No
Popular Solutions for Viking DFUD04 Built-in
Questions and Unsolved Problems for Viking DFUD04 Built-in
Do you recommend Viking DFUD04 Built-in Dishwasher?
Answer
Answer
The dishes on the top shelf do not get clean
Answer
water is not being drained from the dishwasher after the wash and rinse cycle.
Answer
My problem is that the dishwasher does not wash. No difference in cleanliness after running washer.... (More)
Answer
My whirldishwasher Mod. ADG 993/NB door will not close. I've checked to see if there was anything... (More)
Answer
our built in viking dishwasher is leaking causing the water to drip from the ceiling below. how many... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Viking DFUD04 Built-in...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
