It sounds as if you are lacking accessory power to the unit. Insure that the red wire of the Pioneer unit is receiving 12 volts with the key in the accessory and on position.
change the tune mode to standby mode. Then press menu button for few second until clock word is displayed on the screen. Afterward, press the center of the main control button on the right side of the stereo system. The time is now blinking and you can start set the time by pressing upward & downward button for hour and left & right button for the minute
This is taken from the user manual.
If switched on, press the ON button to turn the unit off.
Press the CLOCK/TIMER button for at least 2 seconds so that the clock icon blinks on the display.
Press the MEMORY button. The hours display blinks.
Turn the VOULUME control to set the hours.
Press the MEMORY button. The minutes display blinks.
Turn the VOULUME control to set the minutes.
Press the MEMORY button. The clock starts.
NOTE: the time can be set accurately by pressing the MEMORY button when a time signal is heard.
Changing the clock to 12 hour display.
When the clock is display, press the MEMORY button and hold it, then press TUN UP buttom (this will change from 24hr format to AM/PM format)
Its not the select button, you must have the power off and hold the function button down for about 5 seconds, display will change and you will be able to navigate your way to the clock from there. Hope this helps.
60PL9200D/37 When I unplug it for a while and turn it back on, the
picture starts to come on, but it turns dark. And the red lights on the
left and right side of the power button blink. Sound but no picture.
The Ford Focus has a stereo problem where the display blinks on and off, with or without the ignition on. This is not a power problem.
This problem occurs when attempting to store a radio station when a blank RDS signal is being transmitted.
To restore your stereo:
Insert a CD, stereo will turn on in CD mode.
Press MENU button
Select DEFAULT RESET by turning the right rotary knob and press to select
Select YES by tuning the right rotary knob and press select
Press BACK button
Press the RDS button once, display will read RDS OFF
Stereo will now work properly
To prevent this problem from occurring again, be sure some text is in the top line of the display when setting a stereo station. Do not set a station when the station name is blank in display.
