Question about Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair
How do i disconnect the reverse sound indicater or signal from my Jazzy1121?
  • 27 Answers
It's a software switch. Any Pride dealer will have a programmer gadget that can turn it off.
Posted on Oct 15, 2010
Turn signals on my 2003 honda shadow spirit blinkers blink but wont stay on all the time
sounds like bad connection have to go through them all and indicater switch
Feb 14, 2013 | Motorcycles
Rear led turn signal problems
reverse the wires...led indicaters are sensitive to which way round they're wired in...problem is though that unless you change your flasher unit or wire in ballast resistors they are going to flash too fast anyway.
May 30, 2012 | Suzuki Motorcycles
08 uplander van turn signal clicker noise is not working
find ur fuse box and locate a round silver relay switch pull it and replace it and all should be well!
Feb 24, 2012 | 2008 Chevrolet Uplander
Turn signals stopped working. Fuses are all ok,
sounds like the flasher can might have stopped working, you will need to get it replaced, it regulates the indicaters to blink, when it goes the circuit is gone, time for replacing id say. check the relays in the main fuse box under the bonnet first, try swapping the relay with another one like the horn relay just to test that first.
Jun 21, 2010 | 1999 Cadillac DeVille
Indicaters not working, but hazard lights do
The turn signal and hazard lights work whit "flashers", sometimes this flasher is common, other is independet. Check under dashboard, if is not visible, you can hear the click sound when is activated.
Other review, your fuses for turn signal. More details and wiring diagrams can find in autozone.com (free register). Select the year, make, model for access.
Hope helped (remember rated this help) Good luck.
Nov 20, 2009 | 2000 Ford Escort
Gps auto indicater is not on the road
There should be a setting within the gps software to lock the signal to the road. I have experienced this before and yes it is a pain but there is a fix now for most models.
Nov 16, 2009 | GPS
Signal indicater shows "ABC" and wont return to the indicater bar
okay, this is what i do with mine. Hold down "ALT" then punch in "nmll" while holding down "ALT. It worked for me. Good luck
Dec 12, 2008 | RIM Blackberry 8110 Cellular Phone
Golf mk3 indicater malfunction cuting out
Looks like you have earthing problems. I would check earth connection for indicators. renew if necessary.
Nov 18, 2008 | 1993 Volkswagen Golf
Beeping when backing up
hi pam from the uk ! the reverse signal/beep can be disconnected however there are different methods of how the beep is operated ? in uk some cars have the reverse light bulbs that are also a beep sounder when reverse engaged ? orthe sounder may be a seperate sounder unit at the rear located either in boot? or behind rear fender? or as you mention beep sounds inside boot area?? the sounder may be hidden behind one of the side panels in boot? if you put ignition on and select reverse then try finding beep location? if/when you find it? just disconnect wirefrom sounder and make sure reverse light/s still remain on tape up the wire disconnected out of way? if it is the bulbs that bleep? you will have to remove and fit an ordinary type bulb usually a flasher/ indicator bulb? hope this is of help and inspires you to diy ? best wishes
Nov 09, 2008 | 2007 Toyota Prius
Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair Logo
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
