Question about Vizio L37 Television
The voice and picture are not in synch on some channels. i have an antenna off-air antenna.
  • pellie708 Sep 04, 2010
    i have an outside antenna.
    Genius:
  • 1,112 Answers
Hi:
you may need to get in touch with Vizio for firmware upgrade to solve this problem, Also come cable boxes causes this problem.
Posted on Sep 05, 2010
  • Vizio Master
  • 5,138 Answers
Problem is in the antenna,you need an outside antenna. Mats Electronics has them 1-800-628-1118
Posted on Sep 04, 2010
My Tv no longer registers a signal from the antenna. I can see a picture thruogh my smart DVR and Chromecast but no pic with TV antenna. I bought a new antenna, still no signal.
Is the TV set to air or cable? It has to be set to air/antenna and a channel search has to be done first before a picture will show.
Mar 07, 2016 | Zenith Z50P3 50 in. Plasma TV
I have a VIZIO E552VL TV hooked up to an Over the Air Antenna and want to MANUALY put in channels NOT AUTO SCAN
Not sure if your TV is digital or analog, but I think an analog TV does not have the ability to perform auto scan, so you may be able to manually input the channels. As a kid, my dad installed a rotary antenna, and as it rotated and TV pictures displayed on the screen, dad noted the specific spot on the rotary unit; and every time we turned the set on, we just pointed the arrow on the dial on the unit to where dad noted what the channel number was on the unit, and the antenna turned toward that direction, and the pictured appeared on the screen.
Nov 16, 2014 | Vizio E552VL 55" 1080p 120Hz LCD HDTV
How do I attach an antennna?
On the back of the TV look for the connector marked Ant/cable. This is a silver connection with threads on it. If you have a digital indoor antenna, connect it there. Same goes if you have an outdoor antenna. Now go to the setup screen and select AIR for antenna type. After that do a channel search and select digital and analog channels. Let the TV find all the stations it can. When it's done searching, it will show a picture. You may need to aim the antenna to get a better picture .
Sep 05, 2013 | Sharp Aquos LC-13E1U 13 in. EDTV LCD...
I cannot get a picture on any channel. Not hooked to cable. No antenna. What is the problem?
Most of the TV sets have " Picture Mute" feature which means; if no signal exists on either Antenna plug or on Video input (RCA jack) no picture at all.Blank screen..no audio as well..all MUTED..
to test it ,play a DVD ,you must have pictures and audio together..
Use an antenna ( even a piece of plain cable will work ) ,and run "search" ,you must receive some TV channels thru AIR.
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 09, 2011 | Toshiba MD13N3 13 in. TV/DVD Combo
We can't get any channels to tune in with the over the air antenna.
I solved this problem by purchasing an external indoor HD TV antenna. Once I plugged it into the TV, I received approx 20 channels, picture and sound are fine. The antenna that comes with the TV appears to work only when you are located quite close to the source of the TV signals.
Nov 28, 2010 | Sharper Image TSILCD7PTSD TV
LN826510 works fine w/ DVD. Air channels where
Your antenna is inadequate.
You need to upgrade to a better antenna.
Jun 12, 2010 | Televison & Video
The words "weak signal" flashes on screen at different places and do not receive a picture.
seems like you are using an "off the air antenna" that receives weak signal, you may be too far from the station, go get a roof top amplifier antenna or subscribe to digital service from cable, satellite or at&t uverse. If you think your antenna is getting good signal, try to rescan your tv for available channel. Make sure your TV set up is correct, if you are using Off the air signal, your setting should be set at "Antenna or off the air", then rescan your TV. Normally on Satellite or cable box, you just watch it on video channel or component input, if you are using HDMI then tune to HDMI channel.
Check your connection to make sure they are making good contact. If you can post your set up, I can better solve your problem.
For a resource on "off the air" antenna, go to www.antennaweb.org for help.
Aug 16, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
Smart antenna
Just because you got lots more channels with the old analog broadcasts, it doesn't mean you can get that many with digital. With analog, you could get a watchable picture from a distant station even if it was weak. It just meant the picture might be a little snowy or fuzzy. It's a lot different with digital.
Digital reception is pretty much "all or nothing". That means either you get the channel or you get a "no signal" message. If the signal from the antenna is too weak, unlike the analog fuzzy picture there is nothing at all.
10 channels isn't a bad number, by the way. A lot of people are finding they get far fewer than that, even no channels at all. It all depends on your distance and direction from the station. If you go to www.antennaweb.org and click on "choose an antenna", they can help you determine what stations are on the air around your area, how far away they are, and what type of antenna would be required.
The "best" antenna is the one that gets the strongest signal from the most stations. For your specific location, this might be as simple as amplified rabbit-ears. Or it might mean a large rooftop antenna that you can turn to point right at the station. That option may not be available to an apartment dweller. You might just already have the best you'll get if you're getting 10 channels already.
May 15, 2009 | RCA Universal Remote Control
Vizio L37 Television Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
