Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
Model km-250baf hoshizaki with weighed in correct amount of 404a the head preasure risies to over 400 psi i think it is the txv advise me if i am right
    Sergeant:
    Novelist:
  • 193 Answers
There are a lot of variables that cause high head pressure. Be sure the cool ing fan is operating properly. It should come on whenever the condenser coil feels warm to the touch. It will cycle on and off as the pressures change. A clogged up coil will also cause high head pressure. If you don't have sufficient water flowing over the evaporator plate, where the ice freezes, the head pressure will go up. You need to check the low side head pressure as well. Weighing the charge is a good start to charging the machine , but the first question I would ask is why are you charging it? Was there a leak, or compressor change?
If you had a compressor burnout, did you replace tthe drier-filter?If not, it may be stopped up from burnout residue. That will also cause high head pressure. If you did not vacuum the system there may have been refrigerant still in the system before you started the new charge. Check the items I mentioned and see if that helps.
Posted on Sep 05, 2010
Continental Freezer model F2 404A refrigerant not cooling properly. Replaced cap tube, and filter drier, evacuated, and charged. Box temp not going below 32' and ice forming at beginning of evaporator....
Check the compressor efficiency. See if it will pump down. In most cases, a good compressor will pull down to about 15" vacuum. Also, be sure that the refrigerant amount was weighed in and not done by pressures only.
May 18, 2017 | Continental Freezer Wide...
Hoshizaki km1300maf
Replacing restricted TXV Hoshizaki Ice machine!
Jul 07, 2013 | Hoshizaki Freezers
I have a Hoshizaki model Km-250baf it beeps three times.
3 beeps means it has been in the freeze cycle too long. A stuck float switch can cause this as well as a leaking water valve. Look for that first. Let me know if you need more info.
Feb 06, 2011 | Hoshizaki Freezer Commercial Ice Machines...
3 beeps every 3 sec
3 beeps every 3 sec. = Freeze Back Up Timer. Freeze > 60 minutes.
Yellow LED marked 60 MIN energizes.
Check for F/S stuck closed (up), WV leaking by, HGV leaking by, TXV not feeding
properly, low charge, or inefficient compressor.
Jul 15, 2010 | Hoshizaki Commercial Freezer KM-500MAH
Need to know the design superheat also normal pressures on this unit with 404A refrigerant
The McCall web site has nothing easily found on the 7-7045FT unit.
In answer to you questions, first, what is the expansion device. TXV, Cap Tube, or something else?
Low site pressure will be dictated by the super heat. The high side, in many cases, is usually ambient plus 30, then convert to psi.
Let me know if you need more info. And please double check the model number/ serial numbers.
good luck
Oct 17, 2009 | McCall Freezer 7-7045FT
Hoshizaki km-1300skf 3 beep error code
The 3 beeps indicates that the freeze cycle is longer than 60 minutes. with the suction pressure at 20, it sounds like low on charge (freon). I believe this is an R 404-A unit. Other things to look for are: Stuck float switch (in the up position), Water valve leaking, hot gas valve leaking, txv not feeding properly, weak compressor. Look at high side pressure too. It should not go below 210 psi during the freeze cycle. Low pressure should be in the middle to upper 40's psi.
Let me know if you need more.
Jan 02, 2009 | Freezers
Hoshizaki ice machine model KM-250BAF SERVICE MANUAL
km-450mwb hoshizaki problem is machine strate is ok but to long time ice making , not dropping, two beeps every three seconds what problem i don't no pleas help mi
Jul 30, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Beeping Ice Machine
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
Jul 09, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Low suction pressure high head pressure
That system has a restriction. Most common at TXV valve or capillary tube. Will need to be replaced by Refrigeration company. In this video I replaced TXV valve and filter drier due to the same issue You have. Its Ice Machine, Low side was at 5 PSI, High at 250PSI : 404A; should be around 55-65 Low; 250 -275 High. Replaced drier and TXV, machine works proper.
May 19, 2008 | Hussmann Freezer 12 Facing Straight Glass...
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
200 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
0duro
Level 1 Expert
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
