Question about Maytag MGR5750 Gas Kitchen Range
Oven will not light, broiler is fine - Maytag MGR5750 Gas Kitchen Range
  • Maytag Master
  • 43,501 Answers
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Sep 07, 2010
BROILER HAS NO REGULAR IGNITION DESPITE THE FACT THAT THE VALVE AND IGNITER ARE FINE AND BROILER AND ORIFICE IS IS CLEAN. GAS PRESSURE AND FLOW IS FINE. ONCE LIT (MANUALLY WITH A LIGHTER) THE FLAME W
How do you know the ignitor is fine? The ignitor for the oven is different than that of the burners. Rather than clicking, the oven ignitor will glow red. If when you turn of the oven you don't see a source of red light coming from under the oven bottom your ignitor is bed.
Aug 30, 2014 | Kitchen Ranges
Oven will not light ,broiler and top of range light fine
the ignitor is not working its bad,you should see a bright orange glow below the oven base just as when you start the broiler look up at the top of the oven and watch this ignitor glow before ignition,the bottom should do the same,you can also see this from the back side of the range at the base,if you don't use the broiler you can use that ignitor for the oven ignitor as these ignitors are identical,but then you will have no broiler
May 11, 2012 | Frigidaire Ovens
MGR5755QD CleanDesign Gas Kitchen Range: oven wont light. stove and broiler work fine. bad ...
heatman101
dfasfdas
May 17, 2010 | Maytag MGR5755QD CleanDesign Gas Kitchen...
Oven won't light , but broiler works fine
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 22, 2010 | Kitchen Ranges
Oven not working. Top, broiler, and warmer are working.
Have you checked for proper gas flow into the over or broiler? This is a gas valve back there that will sometimes go bad. Also there is a sensor near your knobs, it is a timer that will go bad, the valve is about 85 dollars and the timer is about 65 dollars
Feb 08, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Hotpoint Gas oven doesn't light
Is the gas valve easy to replace on a gas oven?
Nov 14, 2008 | Hotpoint RGB745 Gas Kitchen Range
Broiler will not light. Oven & top burners work fine
hi thanks for the question check to see if the broiler igniter is broken that could be the problem do you use the broil more than the bake if you do then change the broil igniter thanks the appliance doc
Sep 16, 2008 | GE Spectra JGBP30 Gas Kitchen Range
I have a Frigidaire Gallery gas oven (electronic digital controls). Neither oven nor broiler is lighting. Stovetop burners light fine.
Have to check if there is power at the oven & broiler first.Maybe a bad thermostat located in back of oven wall.
Jun 08, 2008 | Frigidaire Kitchen Ranges
Maytag MGR5750 Gas Kitchen Range Logo
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
