Question about Philips 32PFL5332D 32 in. LCD Television
My Philips 32PFL5522D/05 has been working OK up until recently when about a month ago it decided that it did not want to keep my freeview channels stored so each time I turned on the unit I had to do a channel scan. Then last week I turned on and the digital tv was blue, nothing unusual there but then when I went to access the digital menu nothing would come up! Everything else works OK, analogue tv, wii, ps3 but I can't get up the menu for digital tv and as my channels wouldn't save I cant access any freeview channels. What is the solution to this issue?
5 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: I need a copy of the user manual for 32PFL5522D
Click Philips Support and download free copy of required user manual.
Posted on Mar 13, 2009
  • 476 Answers
SOURCE: digital channels have stopped working, only blue screen!
Try resetting the TV:
  1. Switch on TV and switch to any analogue channel.
  2. On the TV: Press and hold the MENU button.
  3. Menu screen will appear on the display.
  4. Do not release the MENU until the menu screen disappears.
  5. TV will go blank for about 60 seconds and then display initial set up screen.
  6. Follow the on-screen prompts to re-tune the TV.
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
Posted on May 19, 2009
  • 213 Answers
SOURCE: my tv is showing multi coloured snow how can i fix
what you mean you have cable or dish?
is the pix the same way in video hdmi or thur
video 1 2 3 if it is you have a bad panel'
because of the t.con chip
Posted on Aug 12, 2009
vis_ver_01
  • 4 Answers
SOURCE: Philips 5522 LCD 32PFL5522D/05 Can't get
You wont be able to receive ceefax / teletext after the digital switch over. As they were a Analogue service. what you need to do now is use the "Red Button" "Interactive" services as they now incorporate the new type of teletext. If you don't get them you will need to retune the set. if that doesn't work I advise contact Philips Support
Posted on Jul 19, 2011
I need a universal remote code for philips tv 32PFL5522D/05
If the unidentified remote is universal, use code search to find something that will handle some or all functions of your Philips TV. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Jul 26, 2016 | Televison & Video
Why does my tv go into setup mode every time i switch it on
There is a power issue. Are you using a power bar to turn it on and off? If so, don't.
Jun 06, 2014 | Philips Televison & Video
Phillips 32pfl5522d/05 signal problem
Call your tvs manufacturer with all the serial numbers and such easily available. They should be able to either answer your question or tell you who can. Good luck. -SB
Feb 01, 2012 | Televison & Video
Philips Flat TV locks up on one channel and won't change
hi i need help cause my philips47pfl7704dif7 when i turn on the tv it just turn blue and wont let me change sources or channels . Help me.
Jul 25, 2009 | Philips Televison & Video
Digital channels have stopped working, only blue screen!
May 17, 2009 | Philips 37PFL5332D 37 in. LCD Television
We have a Thompson box in the lounge and until recently we had a Technix box in the conservatory. Both gave full coverage and good quality until a few weeks ago, when the Technix box gave very poor quality...
Can you try a non-working box in the Thompson box's location in the lounge? If you swap the boxes in the lounge and they both work normally then you must suspect that the cable supplying the conservatory must be the problem.
Feb 23, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Goodmans GTV69RFDT Television had all freeview now only getting 3 channels
First ensure that the TV input is set on the Freeview channels, just in case.
Then check the antenna, when Freeview does not get all channels, it is always the aerial (antenna).
Many areas in UK have still poor reception. If you use an internal antenna, go to Argos or Currys and buy an amplified antenna for freeview, that will improve the signal.
Oct 15, 2008 | Goodmans W280NS Television
Philips freeview box DTR 220
Same problem with Channel 71 CBeebies. Tried rescanning which worked initially for a few weeks but it's back and rescanning does not fix the problem now.
Feb 14, 2008 | Televison & Video
Digital TV not working
i had same probs tv 4 monts old new tuner fitted
and yet one more new tuner fitted when 8 months old
it now turns pick off at randod but sound stays on have to unplug mains for temp fix
now warranty has run out philips are not interested
Oct 31, 2007 | Philips 42PF9966 42 in. HD-Ready Plasma...
Philips 32PFL5332D 32 in. LCD Television Logo
521 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
