Question about Magellan MAESTRO 3100 98083401 GPS Device
Magellan GPS,Maestro 3100
Battery will not hold a charge. How do I replace it?
  • rduncan7380 Apr 08, 2009
    will not stay active. shuts down
  • graceellens Apr 17, 2009
    The battery will not hold a charge and will not even turn on anymore. Where can I find a replacement battery for it?
    Problem Solver:
  • 11 Answers
IF U HAVE THE UNIT FOR LESS THAN A YEAR, U SHOULD BE ABLE TO CALL THEM AND GET FREE REPLACEMENT FROM THE OEM. BUT IF OVER A YEAR THEN I HOPE U BOUGHT AN EXTENDED PROTECTION PLAN AND THAT SHOULD COVERED IF U DID, IF NOT THEN U PROBABLY HAVE TO BUY NEW ONE----
Magellan GPS
960 Overland Court
San Dimas, CA 91773
USA
Customer Service
North America: Telephone 800 669 4477
International: Telephone 1-909 394 5000
Technical Support
North America: Telephone 800 707 9971
International:
Telephone (France and United Kingdom): 0825 864 865 (Cost of a call : from France, 0.125€/minute: From U.K., cost of a long distance call).
Posted on May 13, 2008
My Magellan Maestro 31100 won't power on
You could have a defective power connection in your Magellan Maestro 3100 which will not allow you to charge the internal battery or power on your unit.
You may try to contact Magellangps.com or Autonav2000.com to see if they can provide you with repair service.
Might be cheaper to purhcase another Magellan Maestro than spend the money on repairs.
Good Luck
Apr 03, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 will not hold a charge
this is very common problem with this and many model magellans.
try the car charger.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Dec 02, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
I can't tell if my magellan maestro 4000 gps is charging.
this could be happening for a few reasons but the most common is that its probably not charging.
before checking anything else, plug your 4000 in to a known good charger, then press and hold the power button for up to ten seconds till it starts.
if that fails, its likely not charging
you can get help to repaired it, here
Nov 09, 2009 | Magellan Maestro 4000 GPS
My Magellan Maestro 3100 GPS unit won't charge anymore. I've seen 2 possible explanations for this problem. #1: The DC power port is broken #2: The battery won't hold a charge any longer How do I determine...
if it starts, you can verifiy if its charging by going to the system settings then power options. the green indicator should be moving left to right. this indicates its charging.
if you disconnect the battery, your magellan should still work while plugged in if the power port is ok.
Oct 15, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Unable to charge the 3100. If charged via car
the Magellan Maestro can not be charged using the USB connection.
make sure green light is on if using the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 800,860,2000,2200t,2500,3000,3050,3100,3140,4000,4040,4050 and the 6000t are known to have faulty dc connectors...if your Magellan gps is not charging or will not power up, its most likely the dc power port.
you can get it repaired here
Sep 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Battery charging problem
most likely the power port is damaged and needs replaced.
i repair those magellan gps if you need help. if i cant fix it there is
no charge. wmetz@comcast.net
May 17, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
My magellan 3100 won't charge
you cant charge a 3100 with the USB connection. most likely the power port is damaged and needs replaced. i repair those magellan gps if you need help. if i cant fix it there is no charge. wmetz@comcast.net
Mar 26, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Won't charge
Are you sure the plug in secure. If not, re-solder the plug. Take it apart and becareful around the plugs on the side
Mar 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
My magellan maestro 3100 won't stay powered on
If the battery is fully charged then press the RESET button.
Jan 20, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan 3100
Replace battery inside. Batteries Plus can get the replacements. See other similar posting from 8-8
Aug 01, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan MAESTRO 3100 98083401 GPS Device Logo
136 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
