Question about Yamaha 5.1-Ch. Surround Sound Home Theater Speaker System
My yamaha htr 5935 turns off by itself after 3 seconds. I have disconnected all the speakers and it still does it.
I had the XM antenna plug come loose. In the process of trying to re solder it I had to remove the small shield over the plug. With the shield removed the reciever would shut off after 3 seconds. Once I soldered the shield back on it stayed powered up. I hope this helps.
Posted on Feb 18, 2011
Tip
Reset factory default settings for yamaha HTR-5650 AV receiver
How to reset yamaha HTR-5650 AV receiver (maybe others) to factory default settings:
1. turn power off.
2. press the 6ch input and stereo button simultaneously for 4 seconds. Then while holding down these 2 buttons, turn the power on.
3. press preset tuning to the right until option #9 is selected.
4. Then, press program button until the *RV option is selected.
5. turn power off, wait 10 seconds.
6. turn power on, settings are reset.
on Feb 10, 2009 | Yamaha HTR-5650 Receiver
My yamaha HTR 5240 comes on for like 2 seconds and then turns off
That proves the audio output stage is shorted on or two channels. It will need to be checked out to assess the situation.
Apr 15, 2012 | Yamaha HTR-5240 Receiver
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
I have a yamaha htr 5890. I would like to hook up
You are probably connected to the pre-out jacks. These are not amplified. Connect them to the B speaker outputs(screw down connectors). If that won't work (and it should), you can connect to the "Presence" speaker connections(spring loaded connections).
Feb 02, 2010 | Yamaha HTR-5890 Receiver
When i turn on my receiver, it starts up for a second and then it turns itself off. thoughts?
first of all , check all your speaker wiring make sure none are touching acrros(frayed) . if good disconnect 1 speaker at a time and turn on unit . if it stys on you found your problem- a shorted speaker.
If none of these things work, disconnected all speaker aand check with a volt ohm meter( you can get a cheapie at Radio Shack)- acroos each speaker you should have either 4ohms, 6 ohms or 8 ohms, depending on the rating on the back of the speaker. if any read lower, replace speaker.
If all else fails, go to yamaha.com/usa and go to support, call service center for repair listed on site.
hope this helps ! Steve A.
Jan 02, 2010 | Yamaha HTR-5760 Receiver
RECEIVER WILL NOT TURN ON.
first you have to test separatly your speakers outputs
disconnect all wires speaker and speakers, turn on your reciever and look if you still have the same problem «CHECK SPEAKER WIRES alert» if yes you have to go to a specialist to fix it... if no test one line after one line with and without speaker connected until the problem reappear to locate the bad line or bad speaker.
Apr 26, 2008 | Yamaha HTR-5650 Receiver
HTR-5940 6.1 Channels
Every time this has happened to me it was either due to incorrect speaker impedance or incorrect polarity (+/- wires reversed).
Apr 21, 2008 | Yamaha HTR-5940 Receiver
Yamaha HTR-5990 Receiver
I JUST EXPERIENCED THE SAME SITUATION HERE IS THE SOULTION YAMAHA SENT ME TO RESET THE SYSTEM HTR-5990 YAMAHA HTR-5990 FACTORY PRESET PROCEDURES All models require the STANDBY/ON button to be turned OFF to start the reset process. NOTE: The remote control cannot be used during the reset procedure. All necessary buttons to complete the reset process are located on the front panel of the receiver. This procedure is not intended to correct intermittent shut-off symptoms or problems MODEL: HTR-5990 (U.S.A. model/s) (BEFORE YOU CONTINUE, PLEASE READ THE ABOVE NOTES!) 1. Before you start this procedure, locate the MASTER ON/OFF button and the STRAIGHT/EFFECT button on the Front Panel of the unit. 2. MAKE SURE THAT YOUR RECEIVER’S MASTER ON/OFF HAS BEEN TURNED OFF. 3. With the Right Hand, press and hold the STRAIGHT/EFFECT button. With the Left Hand, press the MASTER ON/OFF button and HOLD both buttons for no more than “3” SECONDS, AT THE SAME TIME. SP IMP. * 8 MIN. will appear on the display, which indicates you are in the Diagnostics Mode. 4. Rotate the PROGRAM KNOB to the right (ONCE) until the display reads PRESET *CANCEL. 5. Press the STRAIGHT/EFFECT button (ONCE) and the display will change to PRESET RESET. 6. Turn the unit off by pressing the MASTER ON/OFF button. 7. Wait 5 seconds, then turn the unit on by pressing the MASTER ON/OFF button. You have now reset your component to the factory settings. NOTE: Yamaha receivers don’t have to be reset during normal operation. It is not recommended that you reset the receiver unless a setting has been changed that you are not aware of, or the receiver is not operating properly. The reset procedure will clear an incorrect setting that might be causing abnormal operation. GOOD LUCK
May 01, 2007 | Yamaha HTR-5990 Receiver
Yamaha 5.1-Ch. Surround Sound Home Theater Speaker System Logo
722 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
