Question about Hayward H-series Electronic Gas Pool Heater H400
The pilot lights but as soon as I release the pilot switch it goes out
    President:
  • 2,702 Answers
You need to change the thermal coupling,,its that littel bit that the pilot light plays the flame onto this part heats up and it holds the gas velve open if its not getting hot or is broken you could hold the pilot light in for ever and it would still go out as soon as you let the light go,,,it may help if you put the thermal coupl into the pilot light flame
Posted on Sep 04, 2010
Pilot goes off as soon as I release the button
You need to hold the button down for about 3 mins. If it goes out after that long the thermocouple is probably bad. Look at how long the wire is from the pilot light to the gas valve. They come in different lengths.
Jan 18, 2016 | World Marketing Kozy-World 3 Plaque...
Just need to know how to light the pilot on a Montgomery Ward wall furnace model sfb-50219
I can't speak to the specific model but with most pilot lights, there is a switch setting or button for lighting. If you release that switch or button too soon, the pilot will not remain light. Hold the switch or button ON while you light the pilot. Keep holding the switch or button for about a minute until the heat sensor is sufficiently warmed that the pilot light stays on. Good luck.
Nov 13, 2014 | Heating & Cooling
Charcoal grill model no BG7-05
turn gas off and clean out all lines going from gas valve to pilot with compressed air. put the lines back together (be sure they seal)
try the pilot again
Nov 15, 2013 | Fagor Ovens
My Delonghi Propane Heater will not stay lit.
this sounds strangely like a safety switch problem , ill bet the device that confirms the pilot lite lit before going to main burner has a problem
Jan 19, 2013 | DeLonghi SafeHeat Heater
CGA Mclain .Natural Gas boiler issue 70k btu with a effikal ventx damper, model RVGP. There is no blower for ventilation, no control board with lights. Pilot light will not stay lit. have already replaced...
hey Carli suspect you mean the pilot goes out as soon as u turn your gas control valve back to the on position!? If this is so, you will have to probable reset the flue spill switch located right at the exaust outlet. OR, SOMETIMES THEY HAVE ANOTHER LIMIT switch in the same circuit in series. If the pilot goes out when u release the pilot press down knob, then it is your thermo couple is loose or fininshed,or the pilot flame is not aimed properly at the sensor (thermo couple)
Sep 21, 2011 | Heating & Cooling
Pilot light goes out
if the unit goes thru the cycle of heating the water and when temp is met pilot goes out you need to replace the entire temp control if pilot goes out as soon as you release the pilot button you need to replace the thermo couple little copper wire the goes from regulator to inside burner...check for 800 number on front of w/h for warranty info..as regulator can be expensive
Dec 09, 2010 | Reliance Natural Gas Water Heater Control
Intertherm gas fireplace, model BDM 35, pilot goes out
could be thermocuple or pilot blocked clean pilot then try make sure you are turning to on and not back to off i was doing this the other day some go clockwise some anticlockwise
Jan 02, 2010 | Heating & Cooling
The pilot light will not stay lit to light the heater.
The power pile (pilot generator) is defective. It produces a milivolt signal to ensure to keep the gas valve open. If it goes bad, the valve thinks the pilot is out, even when you are holding the button down, so when you release the button, it shuts the gas off to prevent excess gas buildup and a possible explosion.
Sep 10, 2009 | Coleman (5040B750) Patio Heater
Pilot light does light , but as soon as you release the gas knob it goes out
Hi there. You must continue to hold the knob in for at least 30 seconds before releasing. If the pilot still goes out, the "thermocouple" is bad. It's the little tube in the pilot flame. To replace, remove the main burner assembly/pilot. You can get a thermocouple at any hardware store. Ask questions while you are there.
Thanks
Paul
Jul 12, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Hayward H-series Electronic Gas Pool Heater H400 Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
