Question about Oregon Scientific Oregon Gator Mulcher 3N1 Lawn Mower Blade For Dixon 1450Inch High Lift 90400 96303 ()
Need belt diagrams for a dixon 4423 ztr - Oregon Scientific Oregon Gator Mulcher 3N1 Lawn Mower Blade For Dixon 1450Inch High Lift 90400 96303 ()
Mower blades start an stop on Dixon zero turn 42 in deck
PDF]OM, ZTR 5421, 1994, ZERO TURN: CONSUMER - Dixon
www.dixon-ztr.com/ddoc/DIXO/...USen/DIXO1994_USen_5421_.pdf
The information in this operator's manual applies to all Dixon ZTR Model 5421 Mowers. .... Before backing your Dixon Mower; stop, turn around and look. 13. ... startsvibrating, and any damage should be repaired before restarting and ... 13 GA stamped steel construction, 3 blades, 42" cut width, cut height approximately.
Sep 17, 2015 | Garden
Belt pattern for blade drive belt on Dixon ZTR6022
Try googling for the owners manual to view that
Oct 04, 2014 | Garden
Need a belt diagram for a dixon ztr 5023
Dixon 5000 Series Belt Diagram
Jul 21, 2014 | Garden
Dixon ztr 46
unhook the pto safty swicth you might have to jump it or leave disconnetected see if that will help you need some more detail
Jul 04, 2013 | Garden
I need a left rear axle for a dixon mower it is bent so the chain jumps off, and a diagram of the rear assembly. It is blue with the levers between your legs, it has a 12hp motor. I am not sure what year...
You can eventually find your manual here:
http://www.dixon-ztr.com/node2171.aspx
There are a ton of manuals.... on that page. Looks like it will be a tedious hunt with out a model number.
If the link does not work go to
and click on support.
If you can come up with a part number you might be able to get it here:
http://www.lawnmowerpros.com/Dixon.htm
They also have parts manuals on this page:
http://www.lawnmowerpros.com/Dixon/Dixon-Parts-Diagrams.asp
Thanks for using FixYa.
Kelly
Mar 09, 2010 | Mtd LAWN MOWER PART # 903-0382 AXLE...
Oregon Scientific Oregon Gator Mulcher 3N1 Lawn Mower Blade For Dixon 1450Inch High Lift 90400 96303 () Logo
400 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
