Question about Bose Cinemate Digital Home Theater System Speaker
Interface module and/or bass module power problem
The interface module or the bass module, so I am told by Bose tech "Phil", is the reason my CineMate system will not power up. Do you know of any other DIY solutions other than shipping the system back for them to fix.....only to have it break down again.
I have only had this system since Oct. 2007 and this is the second time with the same prob. Fortunately mine is still under 1 yr. mfg. warranty and they covered the cost of the first replacement interface module, which temporarily fixed the power up problem. This time they emailed me a UPS shipping label to send the bass module and interface module back to them, again at their expense. It seems as though it is an ongoing problem with the CineMate and I dont think they have a permanent solution. Do you know if the 3-2-1 including the dvd/receiver has the same problem or is it just the CineMate with the remote interface module.
any asst. will be great.
Thanks
Eric
  • highjump64 Jul 22, 2008
    interface module doesn't power up. this is the second time this has happened. the first time i took it back to bestbuy and the gave me a new one
  • 53 Answers
Eric,
Take their offer Bose is not that forgiving.
Send it back let them deal with it.
If you try to DIY it you'll void warrenty and will be totally SOL
Good luck
Posted on Jun 24, 2008
What do you do when the interface module keeps blinking
you probably have to have the interface module replaced. Pretty common on this model for those to go bad. If you contact Bose, they will repair it for a flat rate fee.
Jul 10, 2014 | Bose Cinemate Digital Home Theater System...
The light on the interface will not come on
Try powering the unit down for 30 seconds and then power it back up.If after pluging and unpluging you still have the fix red led then the IR Detector Module inside the CineMate Interface Module is not working. You have to replace it. The Part Number is 1B83 41A. You can but this part at Radio shack for under $5.00 , remove the old one and solder a new one in, 3 leads of the LED. This was the way I fixed mine
Mar 23, 2014 | Bose Cinemate Digital Home Theater System...
Bose cinemate troubleshooting
If the light on your control console just stays red and never changes, then the control module is probably bad. It's pretty common on the cinemate models.
Jun 06, 2013 | Audio Players & Recorders
Replacement part for Bose Cinemate Interface
Replacement parts for Bose Cinemate Interface can be foudn at amazon, take a look here: Amazon com Bose Cinemate parts. I hope this helped. Cheers
Oct 29, 2011 | Bose Cinemate Digital Home Theater System...
Can the bass and treble be adjusted on the bose cinamate?
There is a bass adjustment knob on the acoustimass module(subwoffer). That is the only adjustment I am aware of at this time.
Nov 25, 2010 | Bose Cinemate Digital Home Theater System...
Same problem. Bose CineMate light went red and doesn't come back green even if I tried changing batteries and doing 5 step approach mentioned above.
If resetting this system and re-seating the interface (box with light) to the bass module doesn't fix this, you may need a new interface module. This sells for about $40-50 from Bose. If this is under it's 1-yr warranty, they should be able to replace this for free.
So just incase you haven't tried it: 1. Unplug the power cord from the bass module (sub-woofer) along with the interface module and wait at least 30+ seconds. 2. Re-connect the interface first- screw it in as tight as can be. 3. Re-connect the power cord, and try the remote again.
This is really the only solution, and it's exactly what their tech support will have you try. That's the one functionally weak point with that system, that little module needs to be adjusted and re-seated from time to time.
Jun 15, 2009 | Bose Cinemate Digital Home Theater System...
Bose Cinemate green led won't come on.
Do the same thing by unplugging the power, but also unplug the interface module (box with red/green LED light) from the sub woofer / bass module, and wait 30+ seconds. Plug the interface module back in first, and screw it in as tight as possible. Then plug the power back in and try the remote. This should fix your problem. :)
If this doesn't fix it, you will have to purchase/replace this module through Bose. (anywhere from $40-$60 if not under 1-yr warranty.) If you're still under warranty, it's a free replacement.
Jun 08, 2009 | Bose Cinemate Digital Home Theater System...
Interface module will not power on
I did the same and it worked once...spoke to "Phil" at Bose today--5/11/08 and after explaining that this was the second time and second interface mod that is having the same prob...he suggested that it is the bass module. So he emailed me a UPS shipping label to cover the cost of shipping back to MA. I am shipping the bass mod and interface mod. He said they will repair at no cost and re issue another 1 year warranty. info only: I have only had this system since Oct of 2007 and I have had the problem twice. The first solution was for bose to send me an interface mod free of charge due to the fact that the system is still under warranty.
If yous is still under warranty, I suggest you call them...if not, either buy another interface or new brand....I think this is an ongoing problem with the cinemate and THEY have NO solution either.
May 10, 2008 | Bose Cinemate Digital Home Theater System...
Bose Cinemate Home Theater
Hello everyone! The Bose interface module is working again. All I did was unplug the power, wait about a minute and then plugged it back in. Whatever it did, it must have reset itself, so now everything is fine.
Nov 18, 2007 | Bose Cinemate Digital Home Theater System...
Bose Cinemate Digital Home Theater System Speaker Logo
1,140 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
