Question about Toastmaster TC17D3 Toaster
Toaster (Toastmaster TC17D3663) will work fine for a while, then the conveyor will stop working. It has a new moter. The heat will stay on, only the conveyor stops. Shutting it off and waiting about 15 minutes makes it work again.
  • tgfuoaklawn Oct 07, 2010
    I have the same exact problem withe same exact model. Replaced the conveyor motor
    also. Heat stays on too, but conveyor stops. Only 2 years old!! I am sick of commercial
    conveyor toaster problems. Everybody says they can repair them but they don't know
    s---- about them. My experience over 30 plus years in the restaurant business is that
    ALL conyeyor toasters do the job well but they don't hold up very long and when you
    get them repaired they usually don't last much longer.
oscarn
  • 110 Answers
SOURCE: Toastmaster toaster
thermostat seems to have given way, needs replacement
Posted on Sep 26, 2007
  • 87 Answers
SOURCE: vintage toastmaster toaster
you will need to adjust the heat switch to a hotter temp. then pull it down. its the slider arm located below the lever.
Posted on Jul 12, 2008
cactus bob
  • 267 Answers
SOURCE: Can an old Toastmaster toaster be refurbished?
there is no manual forthe repair of toasters . but the toaster you have is a common one on e bay , i dont see one right now but there have been a few over the years , and a well used one sells for around 10.00 , it may not work but its great for parts ( i collect and restore kitchen appliances) so i would take a look . you might find a cream puff for 20 .00 and put yours into retirement ..... other than e bay there not a lot of resources out there for parts . good luck ........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Posted on Mar 06, 2009
SOURCE: Toaster won't stay down. Toastmaster Toaster
The contacts on my magnetic lock (lever) had some crumbs and build up on it. I had to take it apart but just cleaning it made mine work fine again.
Posted on Dec 23, 2009
Nomodo4u
  • 863 Answers
SOURCE: toaster needs new heat coil
Find a comparable model at flea shops, yard sales, or e-bay and take the parts off and install them on yours.
Posted on Feb 04, 2010
Oven works but is not heating up what can I do or check for to restore heat
Check for correct power at the heating elements, if its there, the elements are burned or shorted.
Mar 07, 2015 | Lincoln 1301/1346 50" Electric Impinger...
My toaster doesn't give enough heat to use it
follow this test with multimeter, and fix it. God bless you
the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical panel and test the power cord.. If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse.
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostat .
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements
Nov 08, 2013 | Hatco Conveyor / Toaster
Heat is low
please make this test with the multimeter.God bless you
the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical panel and test the power cord If the oven doesn't work on its toaster and oven functions, test the main switch As needed, check the fuse .
If the toaster oven stays on when the door is opened, check the main switch (). If the oven doesn't heat, test the heating elements.
Apw keeps blowing circuit
It may be time for a new toaster, this one could be dangerous. It appers to be drawing lots of current, which would could mean a short inside and could cause a fire.
Aug 20, 2012 | APW Wyott XPRESS (120V) Conveyor Toaster
I have a APW WYOTT XPRESS CONVEYOR TOASTER several years old. When I plug it in and hit the one switch, there is a short in the unit that causes the GFI to blow immediately. Could the problem be in the...
i just had the same problem, it was the power switch, i re routed wiring to bypass bagel switch and it works fine, but you will want to replace those switches as they a junkily made and the heat destraoys them every couple years
Aug 10, 2010 | Holman QCS2-500 Conveyor Toaster
Toastmaster Toaster Oven 357 is not heating when door is closed?
Mine just broke too - it won't heat - everything else works - lights, timer ect. but no heat can't cook
without it - love my oven - any solutions ( I guess it's the heating element ) Hope I can get a new one.
Aug 29, 2009 | Toastmaster 357S Cool Wall 1400 Watts...
Have a apw wyott conveyor toaster, conveyor randomly stops
I had a similar problem I changed the Rear Bearings in the belt & Check the Fan motor in the rear which houses the conveyer Motor wheather it is working or not it could be the fan not working and over heating the motor the last thing is the screws that hold the conveyer motor are too tight as the motor is self adjusting.
Jan 17, 2009 | APW Wyott AT-Express Conveyor Toaster
Vintage toastmaster toaster
Jul 07, 2008 | Kitchen Appliances - Others
Heating elements
I think this is a common problem with these kind of toaster ovens. Mine isn't a Toastmaster - mine is Cook's Essentials (from QVC), and my upper elements have also warped and split, although mine are curved downwards.
Dec 12, 2007 | Toastmaster 328 Toaster Oven with...
Toastmaster TC17D3 Toaster Logo
67 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
