Question about Janome Sewist 525S Mechanical Sewing Machine
One step buttonhole help!! - Janome Sewist 525S Mechanical Sewing Machine
  • 161 Answers
On my machines, the one step button hole requires a pull down sensor that the button hole foot triggers when it has done one side. You put the button in the holder part of the button hole foot, set up with sensor and start to sew, being careful not to touch the trigger, then the machine will sew the required length, change stitch and then do other side. Maybe there's a demo on you tube ? I hope this helps
Posted on Sep 13, 2010
How do I fix a onestep buttonhole that is sewing only on one side?
I am giving a link for the basics of a one step button hole. Next time include the machine make and model for addtional help.
One Step Buttonholing
Mar 01, 2015 | Singer Sewing Machines
My machine has a one Step Buttonhole Feature - having problems
Try an Even Feed Walking Foot for more control on thick and quilted type layers
Dec 10, 2011 | Brother CS6000i Computerized Sewing...
When I press the button to make a buttonhole and step on the power, all I get is a beep. How do I make a buttonhole in that one easy step?!
Is there a little arm you need to pull down behind the presser foot? And a buttonhole foot that needs to go onto the machine?
Do you have a manual for it to check out the buttonhole procedure? try this link
http://www.singerco.com/resources/buttonhole.html for some instructions and images but always good to have the machines manual if you can get one.
Many of the machines with the one step buttonhole function have a white plastic slide type foot and the buttonhole lever that you pull down. You put a button into a clip at the back of the foot to "measure" the buttonhole length. Then start sewing, the machine will do a bartack, then start backwards, the pulldown lever will then connect with the foot when it gets to the right length, start the end bartack, then reverse back up the other side of the buttonhole and finish off when it comes back to the start of the foot.
The Singer will probably be some variation of this system, hope this helps.
Mar 09, 2011 | Singer 7422
HOW TO USE BUTTONHOLE FOOT AND WHAT SETTINGS ON MACHINE
From what I could find, this machine has a one-step buttonhole feature.
I found these instructions for a Singer one-step that may be of help - http://www.singerco.com/resources/buttonhole.html
May 08, 2010 | White Sewing 955 Mechanical Sewing Machine
Can't figure out automatic buttonhole use on MC4000
2 things must do:
You have to use the buttonhole foot.
You have to pull down the lever to the lowest position (just left of needle bar/ presser bar up in machine.)
Set to buttonhole. After each buttonhole, be sure to change off the buttonhole then reset to buttonhole to reset the buttonhole to the beginning
Mar 15, 2009 | Janome Memory Craft 4000 Sewing Machine
Buttonhole
I'm afraid that you are unable to correct this glitch on your own. Any sewing machine service center/shop will do...call around and look for the shop with the lowest 'minimum' charge. It is such a simple fix. However, although simple, the adjustment is so incrementally precise that without thorough understanding, your stich patterns could be rendered unuseable. I have no idea of the current value of your sewing machine, but if you deem the repair costs prohibitive, there is a workaround so you can complete your buttonhole. Complete your buttonhole setup as normal. I assume that you run tests first to adjust your stitch length/density of the buttonhole using the Step 1 setting. When you find the the length/density that you want, using an ink marker/crayon...whatever...being as precise as possible, mark a linear line from the edge of your length selector dial, continuing to the body of your machine. Now, select Buttonhole Setting #3, and increase the stitch length until you see the length/density that you want. Find a clear spot on your length dial and repeat the marking procedure. When you are ready to make a buttonhole, align the markings for Buttonhole Step 1 on your stitch length dial and proceed, complete your tack of step 2, stop, manually raise your needle out of the fabric using the balance (hand) wheel on the right, adjust your stitch length dial accordingly for Step 3, then on to your final tack #4. If it's only your buttonholer that is giving you trouble, take the extra 15 minutes or so, and use the workaround and mark your machine. It doesn't have to be ink, it can be pinstriping tape...whatever, and spend the money you saved on fabrics and notions instead.....good luck my friend.
Jul 27, 2007 | Singer 2732 Mechanical Sewing Machine
Janome Sewist 525S Mechanical Sewing Machine Logo
249 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
