Question about Onkyo TX-DS575 Receiver
I need a replacement volume knob for a onkyo tx-ds575
SOURCE: No Sound - LCD Volume says 99
- make your room as quiet as possible, then put your ear next to one of the tweeters (high frequency speakers; the smaller ones).
- If you hear any noise, probably a soft rushing noise or a hum, then your problem is probably an input source problem, not the amplifier itself.
- Plug in some headphones, and see if you can hear your music that way. If so, then the problem is probably the amplifier section, or your speakers, or your speaker connections, not an input.
- Turn the volume down, then look to see if a Tape Monitor button is pushed. If so, "unpush it".
- Check for any mute function that might be enabled.
- If you hear NO NOISE with your ear next to a tweeter, then verify your speaker connections; and check for blown speaker fuses (you'd expect to see a matched pair, one per channel).
- also check your speakers to see if they have fuses
- double-check your speaker connections; verify no shorts, and tight mechanical connections
Posted on Nov 10, 2007
  • 54 Answers
SOURCE: Onkyo TX-DS575 - intermittent audio
You have a problem that was inherent with all Onkyo receivers from this period. You need to contact Onkyo because the microprocessor needs to be replaced. Last I checked, its about $80 from onkyo.
This is NOT an isolated incident as darn near every Onkyo receiver model had this problem.
Good luck...
Rob
Posted on Nov 15, 2008
SOURCE: i need the remote code for my onkyo tx-ds575, my
Get yourself a remote from Logitech Harmony family. It magically knows all the possible codes. And the support is VERY helpfull.
Posted on Mar 28, 2009
tvservice306
  • 458 Answers
SOURCE: onkyo tx-ds575 receiver shuts down when switching
may be speaker or wire have problem
Posted on Oct 28, 2009
dunnbiker
  • 8546 Answers
SOURCE: hello. I have some problems with
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Posted on Jul 08, 2011
Replacement Volume Knob Onkyo TX-5811
Maybe the cheapest and the best way to get the knob is to check ebay and buy the hole receiver for parts or check the link below. :) hope it helps
https://www.partstore.com/OpenSearch/Model/Onkyo+Corporation/Onkyo.aspx
Jan 29, 2014 | Onkyo Audio Players & Recorders
I have lost the remote control of my Onkyo TX-DS575 AV reciever/DTS Amp and cannot find one in the market. I have used a universal remote which had a couple of Onkyo codes with it but it doesn't work. Is...
Amazon.com, MyRemoteControls.com, and Remotes.com all sell a replacement remote for the TX-DS575. I have also seen the Onkyo TS-DS575 receiver with remote listed on eBay for as low as $35. Keep looking; the remotes are out there.
Jan 22, 2014 | Onkyo TX-DS575 Receiver
OWNERAS MANUAL TX DS575
You can get the manual on the link below.
http://www.intl.onkyo.com/downloads/manuals/pdf/tx-ds575x_manual_e.pdf
If that is not the right on then go to this link below and click where it says it is free
http://safemanuals.com/user-guide-instructions-owner-manual/ONKYO/TX-DS575-_E
Good Luck and please rate 4 thumbs up for the free answer
Sep 03, 2010 | Onkyo TX-DS575 Receiver
Look below
This model has bad solder connection located on bottom of receiver.you may also see a burnt spot on top of the board towards front center.connections under that burnt spot will be bad.
Apr 02, 2010 | Onkyo TX-DS575 Receiver
I need the remote code for my onkyo tx-ds575, my remote isn't working and i want to program another remote to control this unit.
Mar 22, 2009 | Onkyo TX-DS575 Receiver
Onkyo tx 906 amp
1) I bought the same Onkyo model from goodwill a couple years ago and it had the same problem. The solution is simple: Get yourself some Deoxit D5. This is a spray that will clean out all the oxidation in the volume pot. To do this you'll need to remove the cover of the receiver. Deoxit can be bought at guitar shops, or if you know a musician they might be willing to do it for you.
2) User manual is available for download, for free. Google "Onkyo tx-906 receiver manual".
Mar 17, 2009 | Onkyo TX-DS575 Receiver
Good luck...
Rob
Nov 15, 2008 | Onkyo TX-DS575 Receiver
Will not power up but stand by light is powerd up
I have onkyo tx-ds575 and i need to conect it to my tv and have audio from a LCD flat panel.
Oct 05, 2008 | Onkyo TX-DS575 Receiver
Onkyo ts595 goes into protect mode with volume increase
Hold the VCR/DVR button in and press the ON/OFF Standby button. The display should briefly read CLEAR and then the unit switches off. If that clears protect mode, you'll need to redo the Audyssey and configuration setup as these will have been cleared by the reset.
Sep 27, 2017 | Onkyo TX-DS575 Receiver
Need fiber optic input jack for Onkyo TX-DS575
Had it ever worked, or are you setting it up for the first time?
Have you ASSIGNED the digital input in the menu?
Dec 18, 2007 | Onkyo TX-DS575 Receiver
Onkyo TX-DS575 Receiver Logo
303 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
