Question about Siemens HF26056GB 1000 Watts Microwave Oven
Have Seimens microwave/oven serial number HB86K570B. Oven working O.K.. mirowave flasing up fault E 10. Can you help? . Thank you. Irene Lugg
3 Suggested Answers
SOURCE: Siemens HF 87960 GB Microwave/Combo Oven
Please, Can somebody tell me where can I get one of this oven??? Thanks Andy
Posted on Feb 26, 2008
SOURCE: sienens microwave HFT879 fault
Exactly the same problem over here, but after our house was hit by lightning, so not really surprised about the cause of the problem. If you look closely, you can still see the displays on a very low light level. I can still choose a microwave program, turn the time etc, and see the time changing, but start won't just just work.
m.de.man att zonnet.nl
Posted on May 05, 2010
My Electrolux above oven convection microwave chimes are not working. Solution?
Hello friend, thank you for your post!
I understand that the chimes on your oven and microwave are not working. I would be happy to help you locate any additional information regarding the chimes. In order to assist you further I would need to have your model number. You can locate the serial tag (which lists your model number) on the inside wall of your microwave or on the door frame. Once I have that information I would be happy to assist you. -Matt
Dec 19, 2015 | Electrolux Microwave Ovens
THE MIROWAVE FAIL TO WORK BOTH MICRO SWITHES ARE OK ?
I have the same microwave. As far as I can tell the inverter went out to the first one. I now have two and use the first one as spare parts. But that said I tried to use the new inverter in the old oven and is didn't work. so I had to be leave the problem could be the control board.
May 15, 2014 | Panasonic NN-T888S Convection/Microwave...
Mirowave wont start
I assume from your description that you can set power and time but nothing kicks in when you press start?? This could be a control panel fault but may be a problem with the door lock/switches. Check that the spring on the door hooks is ok, just lift it up and check it returns to down position by itself. If the microswitches do not make properly when the door is closed the m/w will not start because it assumes the door is open. A microwave (even when switched off) can be storing a high voltage so unless you are trained I would suggest you get an expert to take a look. BSH is Neff service division 0844 872 8999, they offer a one off repair plan, which covers your first repair and then any further repairs for a year. You can pay monthly by DD to spread the cost. (This may be age related so as yours m/w is nearly 10years old, it may not be eligible).
Hope this helps.
Mar 21, 2013 | Neff Microwave Ovens
Everything works except it won't heat anything. can you tell me what is wrong. it is a sharp microwave, model # r-306 lk, serial # 85407. thank you.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hdshj
Apr 21, 2010 | Maytag MMC5000 Microwave Oven
Belling BEL-CJ/SS25 microwave
My Belling BEL-CJ/SS25 Microwave / oven / grill has recently developed a problem. Every time I close the door the turntable starts rotating, even when I'm not using it. It doesn't make a noise, and doesn't seem to be going into any cooking setting, and the light doesn't come on, but it turns until I open the door, when the light comes on and the turntable stops turning. This has only recently started happening, and nothing else seems to be wrong with it, Is this safe or should I get rid of it and buy a new one. The guarantee has expired so repair may be cost prohibitive.
Sep 04, 2009 | Microwave Ovens
F3 flashing on display screen..no buttons work!
I have the same problem. However when I unplug the microwave from the wall outlet, let it sit for 10 seconds, then weird codes appear on the top line. Reset the clock and it shold work just fine.
zayd4@aol.com
Apr 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Smoke bellowing out the top of microwave
hi my name is mark, sounds like you burned up the high voltage transformer or the fan motor. or the transformer for the control board. if oven cycles but does not heat its the HV transformer. hope this helped. thanks for your question.
Mar 18, 2009 | Jenn-Air JMC8130DD Microwave Oven
Siemens HF26056GB 1000 Watts Microwave Oven Logo
125 people viewed this question
Top Siemens Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Bill Olaschinez
Bill Olaschinez
Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
