Question about Canon CanoScan FS2710 Film Scanner
My FS 2710 is sczi interface how can I use it with my new computer with windows7 with only USB or firewire connections
    President:
  • 2,571 Answers
You would need to buy a scsi card , or take the card out of the old pc, you may have problems finding windows 7 drivers tho.
It says you need scsi II card
Posted on Sep 04, 2010
Mackie 402VLZ4 4 how to connect to pc
It depends on what I/O is available on your PC. If it has an analog input (typically a stereo 3.5.mm connector), you can connect that to the mixer's Tape Out connections (cable needs 2 RCA plugs on one end, 1 3.5mm stereo plug on the other).
If the PC only has USB or Firewire connections, you need a computer interface. Something like an M-Audio M-Track or PreSonus AudioBox USB. Connect from the mixer Tape Out to the line inputs on the interface. Connect USB (or Firewire) from the interface to the PC.
Jun 30, 2014 | Mackie 402VLZ4 4-Channel Ultra-Compact...
I purchased a Pinnacle Dazzle to connect my Sony DCR-HC38 to my computer. I do not know how to connect the camcorder to the Dazzle device.
Sony DCR-HC38E should have an interface called 1394, or the firewire. so you need to use a FireWire cable to connect it to your computer's firewire interface, some laptops have it built-in, If you don't have one on your computer, you can either purchase a IEEE1394/FireWire adapter, which should be under 100 or even $50.
Connector Type1.0 x Composite video/audio output , 1.0 x S-Video output , 1.0 x USB , IEEE 1394 (FireWire/i.LINK)
Sep 09, 2011 | Sony Handycam DCR-HC38E Mini DV Camcorder
Hi, i want to no, what is 1394 on motherboard and if the usb cable in the front write 1394, i install it like a regular usb cable?????
It is Firewire port/ Interface. The IEEE 1394 interface is a serial bus interface standard for high-speed communications and real-time data transfer, frequently used by personal computers, as well as in digital audio, digital video applications etc. The interface is also known by the brand names of FireWire (Apple), i.LINK (Sony), and Lynx (Texas Instruments). This is not as widely used.It works just like USB but it is meant for connecting Firewire capable devices. If you have any firewire capable device (like video camera)and firewire cable, you can connect the device to your PC and use it for high speed data transfer.
Hope it helps! Good Luck!
CreativeTECH
Apr 18, 2011 | Foxconn 661MX Motherboard (FOX661MXMB)
Hi im trying to transfer 8mm tapes to my computer?i have down loaded new software but when i hook up computer says it cant locate i,link cable?i have hooked up provided usb cable but it wont reconize it?
This type of camera usually downloads better with a Firewire (Sony call this i.Link) connection. Some mini-DV and D8 cameras only use the USB connection (if they have one) for stills and can ONLY download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The DCR-TRV265E definately has to use Firewire.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My camera came with the correct lead.
There is a Sony tutorial page for downloading video to computer at THIS LINK You will need to select Windows as the operating system, then Digital8 as the camera type, then select the type of connection. As you will see, the USB option warns that it won't work with many cameras, and you are strongly recommended to use i.Link (which everyone else calls Firewire).
Jan 04, 2011 | Sony Handycam DCR-TRV265E Digital...
I have a Panasonic PV-GS39 and want to put my movies onto computer that's running on windows 7. Using the USB cable doesn't work. Will the firewire cable really work or am I just out of luck? Thanks for...
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The way it works on my computer, the camera is controlled by the computer software.
Whether this will work with Windows 7, I am not sure. My Mini-DV camera, using a Firewire cable, didn't need any camera driver loaded to the computer, just the movie editor that came with Windows XP.
Dec 07, 2010 | Panasonic PV-GS39 Mini DV Digital...
How do it ransfer video from my pv-gs9 to my computer xp. i have a new firewire to usb cable but my computer won't recognize it.
I don't understand the "firewire to USB cable" reference. You can't just connect these two incompatible interfaces together with a cable. There is some kind of conversion device available to allow a Firewire connection to be made to a USB port, but the chatter on the forums says that it doesn't work with video cameras.
Some mini-DV cameras have a USB port, but only use it for stills and can only download video by Firewire. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
You don't say if you have the manual available for reference. If not, you can download a copy from THIS LINK
Nov 17, 2010 | Panasonic Palmcorder PV-GS9 Mini DV...
Want to downlaod to computer via usb, but computer doesn't see device
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection for stills (if they have one) and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file.
Nov 11, 2010 | Sony Handycam DCR-TRV27 Mini DV Digital...
Connecting the Canon FS 100 to my iMac
jhobby2000 buy a usb 2.0 specially for SD or SDHC chip
Dec 31, 2008 | Canon FS100 Digital Camera
Firestore FS-4 no longer recognized as external drive by Macs
bad firewire port try getting a new firewire card throw usb many or pcmia pci card for desktops
Jan 30, 2008 | Video Cameras
USB Port
To transfer video to your computer from the ZR100, you will need to connect the camera to the computer via the firewire interface. The ZR100 does not have a USB interface.
Jan 19, 2008 | Canon ZR100 Mini DV Digital Camcorder
Canon CanoScan FS2710 Film Scanner Logo
214 people viewed this question
old marine
old marine
