Question about Fisher and Paykel DEGX1 Electric Dryer
Fisher paykel smartload dryer degxius does not dry cloths. Drum is hot, and lint basket is empty. I have cleaned lint out behind lint basket.
  • 32 Answers
Check and make sure that your exhaust tube and outside vent are not clogged. If they are clean them out and you may have to buy and new lint screen that come with a seal whcih will solve your problem. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ . This forum will further help you through your problem.
Posted on Oct 15, 2010
My Fisher Paykel gas dryer gets way too hot on the right side. I can only use the lowest setting to dry my clothes. The side with the bearing gets so hot at any other setting, that you can not touch
Hello Anita;
My name is Peter. I am a retired field service appliance technician.
You did not provide a model number so I am not sure what components you have in your dryer.
So, these are possibilities:
1.) You may have a bad high temperature limit switch.
2.) Your gas regulator spool valve may be worn or stuck open. There is a setting screw on your gas regulator valve. Turn to the right to reduce gas flow and turn to the left to increase gas flow.
1/4 turn at a time.
3.) Your gas flame tube may have slipped forward or moved redirecting either the flame length or directing the flame at the bearing.
Nov 24, 2014 | Fisher Dryers
Hi, My dryer has stopped dying the my cloths is this a common problem?
No, is the dryer drum spinning? If not, replace the drum belt. If the drum is spinning but not drying the colths. The dryer heating elements is burnt out and needs to be replaced. GB..stewbison
Aug 31, 2011 | Fisher and Paykel SMARTLOAD DE62TG1...
Drying is taking a long time. Vent line is clean, and dryer is not beeping like it normally does if there's a restriction. Also cleaned the drum exit ports of lint. The heating element appears to be...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Mar 19, 2011 | Fisher and Paykel SmartLoad DG62T27G Dryer
Dryer not drying clothes, have had a small load in for over 2 hours still wet....
Hello s cissy. If the clothes are hot but not getting dry you probably have lots of lint accummulated in the vent pipe which is stopping the wet air from escaping to the out-of-doors. To solve this pull out the dryer, unplug it and then disassemble the vent pipe from the lower back of the machine. Clean out the inside of the pipe and the interior of the machine where the pipe connects.
If the clothes never get warm to hot, then you most likely will have to replace the heating element. Get back if that is the case and we can talk you through that repair. Joe
Thanks for choosing Fixya!
Nov 22, 2010 | Fisher and Paykel SMARTLOAD DE62TG1...
Top load Fisher Paykel dryer doesn't get real hot and therefore is very slow to dry clothes. I've checked the lint filter and the exhaust pipe is clear, so air is moving freely through. It seems it must...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Fisher and Paykel SmartLoad DG62T27G Dryer
Is not getting hot.have cleaned the lint basket and pulled the basket holder and cleaned behind it. still not getting hot. could it be the heating element?
Deffinitely the next thing I would test. If it is tumbling and the timer is working, save having a wiring issue, which is highly unlikely, it probably does need a heating element.
Dec 07, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
314 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
