Question about GE Spacemaker JVM1640SJ Microwave Oven
My microwave smells like electrical wires burning, what could be the cause?
5 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: burning wire smell
Hello jvtmad1,
All of the previous comments are relatively good ideas but let me offer some additional advice,
First off, You need to determine if the burning smell is coming from the Microwave itself or from the receptacle that provides power to it. Most wall receptacles are rated for 15 amps and should easily handle your microwave ovens power requirements. A simple check might be to run a hair dryer on the same receptacle without the microwave plugged into it. They draw comparable power so that should eliminate the recptacle as the culpret, On the assumption that the burnt wire smell is coming from the microwave itself, then your best bet is to return it to the store for a repair or replacement. Unless you are properly trained on how to sservice that, you probably shouldn't attempt it. As stated in previous comments, it should still be under warranty. If you have a bad filament transformer, magnetron or the wiring between them, that is not something you want to fiddle with yourself.
In summary, eliminate the receptacle on the wall as being the problem first.
If you find tha your receptacle is the problem, then you may be able to remove or disable power to it by switching off teh appropriate circuit breaker or fuse.. then take off the face plate and check the integrity of the wires going to that receptacle and making sure they are tightly secured to the terminals of the receptacle. I would assume that if that were the problem, you would notice a burnt smell as soon as you took off the face plate. Hope some of thes ideas help you resolve your problem...
Regards,
Rick
Posted on Nov 22, 2008
heatman101
  • 43501 Answers
SOURCE: microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 07, 2010
  • 13 Answers
SOURCE: ge microwave oven wall smelling wire burn!!!!
time to put it to rest
Posted on Jan 02, 2009
localwonder
  • 6784 Answers
SOURCE: MICROWAVE IS NOT HEATING
HI, the actual device that produces the heat is damaged or faulty. this device is called the Magnetron. you will need to replace this part in order to restore the heating ability of this microwave oven.
Please rate and have a great day:)
Posted on May 29, 2009
We have a GE profile microwave with inverter tech that will come on for about 5 seconds then shut off. Unplug it and plug it back in it does the same thing. It lets off a terrible smell almost like a...
Remove vent grille, then remove control panel. Check wire to cavity thermostat. Sometime wire bundle and small space causes poor terminal connections on this thermostat and will burn wire terminal. Cut off bad part of the wire, install a small terminal end, reconnect to thermostat. If thermostat is destroyed, also replace thermostat.
Aug 13, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
My 1000 watt microwave gave off electrical burning smell then stopped working
check inside after removing power... look for melted plastic or burn spot inside.. bad fuse or wire connector.. replace as needed
Apr 09, 2014 | Hamilton Beach Microwave Ovens
Burning smell or smell stuck in the vent?
sweet smell from an electrical appliance is ozone cause fir high voltage discharge ( like the sweet smelling air after a lightning strike
take it in for a proper diagnosis
May 31, 2017 | Microwave Ovens
Whirlpool over microwave combo has burning smell in microwave
Probably fragments of food burning on the waveguide cover.
Jul 31, 2017 | Microwave Ovens
Electrical burning smell
It is hard to tell what is burning, take it to the repair shop
Mar 12, 2013 | Oster OGG61403 Microwave Oven
MIcrowave emits an electrical smell while cooking. It still cooks, but has started emitting an odor recently when in use.
Is the smell ionized (the outside smell of a cold winter morning air) or more of an electronic component burning??? if it's more of an ionized smell it could be normal, (if the smell is strong) it could be a leaking high voltage cable (electric arching) bad insulator, if it's more of an electronic component burning smell, it could be a overheating component, in both cases you should have it checked by a professional technician...
Cheers!
Jun 25, 2011 | Sharp KB-6024MS Stainless Steel 1000 Watts...
Not heating. Electrical burn smell.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101][[\\[]
May 19, 2010 | GE JVM1440 Microwave Oven
Heard a pop and then an electrical smell. Unit is working but a faint electrical smell occurs each time unit used. Should I continue using it? It is built in with a trim kit.
No that is a very dangerous situation. What is sounds like is you had a short that blew apart but not completely damaging the wires. You should unplug, and open it if its out of warranty and inspect the wires. If the wires are partially burned it can heat up and cause an electrical fire.
May 19, 2010 | Panasonic NN-S541 Microwave Oven
Wire burning smell from Microware
unplug it.....if on fire, use dry chen extinguisher, if still persistent, dial 911 n get out of the house
Apr 23, 2010 | Thermador MBBS Microwave Oven
Burning smell from Microwave
If you clean any appliances always plug out the unit power supply do spray any liquid in the unit that can enter inside the control, instead just wipe it with rug not spray. In this situation you have to call for a qualified technician. Maybe there are some wires that burned or rust in the control that cause the short circuit inside the unit..
Dec 27, 2007 | Whirlpool MH7135XE Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
4,552 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
