Question about Maytag Neptune MDE5500AY Electric Dryer
Sensordry works about 5 minutes goesfrom 50 minutes to 9 minutes
  • Maytag Master
  • 3,053 Answers
Hello, akc I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
Beko sensordry 6kg gets hot on sensordry programs but won,t get hot on timed programs and keeps stopping and starting, any ideas please?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!!
Feb 13, 2015 | Dryers
I have a Westinghouse Sensordry LD505E Dryer which has suddenly stopped heating up
Either your dryer vent is clogged or your heating element / ignition coil has failed. It's called a hot surface igniter
May 19, 2014 | Heating & Cooling
50 inches LG PLASMA TV TURNS OFF AFTER 15 MIN.
A blown capacitor might not be the reason. After 15 to 20 minutes of work, the temperature inside the set do rises much, this kind of fault can occur. Check its cooling fans.
Jun 25, 2013 | LG 50PT350 50 in. Plasma TV
I need a new high pressure line that goesfrom the compresser to the tank where do i go`?
What you are looking for is called an unloader tube. I have used cooper water line for a refrigerator ice maker to replace the plastic. Its a little hard to work with because it is not as flexable as the plastic stuff, but it works the same and is not as likely to were out as fast. You can get the cooper line from any hardware store.
Mar 04, 2011 | Clarke Power Products Inc AC2001 2HP 4...
Working alone,Maria can complete a task in 100 minutes.Ann can complete the same job in 2 hours.They work together for 30 minutes when Liu,the new employee,joins and begin helping.They finish the job 20...
Check my work, before you hand it in -- there could be some DELIBERATE errors in my fractions. :-)
Marie takes 100 minutes for 1 job.
Marie took 50 minutes for 1/2 job.
Ann takes 120 minutes for 1 job.
Ann took 30 minutes and did 1/4 job.
Ann took 20 more minutes and did 1/6 job.
Together Marie & Ann did 1/2 plus 1/4 plus 1/6 job in 50 minutes.
Together Marie & Ann did 6/12 plus 3/12 plus 2/12 job in 50 minutes.
Together Marie & Ann did 11/12 job in 50 minutes.
Liu did the rest (1-(1/2+1/4+1/6)) job in 20 minutes.
Liu did the rest (1-(4+3+2)/12) job in 20 minutes.
Liu did the rest (1-9/12) in 20 minutes.
Liu did the rest (1/4) in 20 minutes.
Liu worked for 5 minutes.
Sep 17, 2010 | Computers & Internet
Sony KDS-R50XBR1 50 in. HDTV picture cycles on and off
It is clear symptoms of weak lamp in TV, replace lamp to correct that problem.
Lamp replacement is easy and written in user manual of TV.
Please buy Sony original lamp for TV safety.
Thanks.
Nov 17, 2009 | Sony KDS-R50XBR1 50" HDTV
White Knight sensordry tumble dryer which only works on low heat
Could be element or thermostats, element is twin giving two heats ie !00watt/ +1800watt, possible one side has gone, you bcan check with multimeter and compare readings..Good luck
Oct 01, 2009 | Dryers
Mits rear projection VS-4543
i wouldahve the power supply checked out,,,it sounds like it may be getting weak
Jul 08, 2008 | Mitsubishi VS-5043 50" Rear Projection...
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
