Question about Audiovox Jensen MSR4050G Am/Fm/Cd Siruis Ready Stereo
How do you remove a jensen msr4050g radio from dash?
AUX IN not working on Jensen MSR4050G
Audio from a DVD player is at line level and the Ipod is at ear phone level. You popped the input circuitry of the 4050. It probably can be repaired.
Jul 28, 2017 | Jensen MSR4050G CD Player
Jensen MSR4050G Sirius Ready marine radio
Sirius Mode Selection
While in Sirius satellite radio mode, press S-MOD (22a) (also the SHIFT/SCAN button) to select
from four available modes: Normal, Category, Direct Tune and Set Skip Channel. When the
Category or Set Skip Channel modes are selected, the corresponding icon appears in the display.
When the DIrect Tune mode is activated, the alphanumeric display appears.
Click on this link to get the user manual:
http://www.asaelectronics.com/techpdf/MSR4050G%20Owners%20Manual%207-11-05.pdf
good luck...
May 19, 2008 | Jensen MSR4050G CD Player
Unit powers up and beeps when buttons are pushed. All the menus work and everything looks alright but there's no music in any mode. Hit reset and checked wiring and fuse on back of unit. Any ideas?
if you have power it wouldn't be a fuse. if there is no audio, it could be a bad speaker (or more) causing the problem. a bad or shorted speaker can cause the radio's amp to overload and shut down. use an ohm meter to check the speakers and the wiring. above 4 ohms is a good number. below2 could cause problems.
May 10, 2011 | Jensen MSR4050G CD Player
I am trying to remove my jensen cd315x am/fm/cd receiver from my 2001 chevy silverado 2500, but can't figure out how! It has been cutting out and lights going off, I believe I might have a loose...
if im not mistaken i you have to pull your dash off then behind the dash you will have about three or four screws holding your radio in place after removing those screws you should be able to take your radio out as far as puling you dash you will need to look for about two screws usually on the bottom if not the check in to make sure before you go yanking on your dash that you have removed every screw so as you dont break it
Oct 29, 2009 | Jensen CD-315 X CD Player
Error Code Displayed When CD Inserted
Error 01 is normally on most machines to say it cannot read the discs. Could be dirty laser or a defective one. Must open to make better diagnosis.
May 12, 2009 | Jensen MSR4050G CD Player
Can I buy the face only to the jensen marine mcd 5110
Do you still need the face plate for a 5110? I have one with case. if so e-mail me @ r.ruditz@att.net
Nov 29, 2008 | Jensen MSR4050G CD Player
Jensen MP5720 radio/faceplate connector is broken or missing spring
I was always afraid this might happen to me so I never removed the faceplate from the radio. This strategy worked fine for two years until two weeks ago. I didn't lock my car because of the freezing rain and somebody stole my faceplate and remote. Anyway I ordered a replacement radio from Amazon last week so I don't have rewire a new one. The replacement cost me $100. I don't really need the rest of the radio so make an offer, my email is cs1713@sbcglobal.net
Regards, Chas
Sep 18, 2008 | Jensen MP5720 CD Player
REPAIR FOR A JENSEN IN DASH DVD/RADIO RIBBON CABLE
Call 919 562 5445 or Fax 919 556 7272 or visit their website www.jensenmobileaudio.com
Jun 16, 2008 | Jensen VM9410 Car DVD Player
I had the same problem and there are a couple of reason why you may not be able to get into Sirius Mode.
  1. You have the wrong type of antenna (it must be a Sirius approved antenna)
  2. You may not have installed the tuner (most Sirius ready units need require that you have a tuner hooked up to your unit to get satellite reception. The tuners are specific to your unit, so make sure you but the correct one. This is quite sneaky on Sirius’ part…but good luck).
Clock
Unplug the unit for a few hours. If the display still does not work, you have a bad display driver or the backlight is bad. Good Luck
Jun 28, 2007 | Jensen MSR4050G CD Player
Audiovox Jensen MSR4050G Am/Fm/Cd Siruis Ready Stereo Logo
98 people viewed this question
Top Audiovox Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you an Audiovox Boating Expert? Answer questions, earn points and help others
