When the water is set to cold it trickles out but when set to hot it flows normal, I have checked both water lines and they are fine going into the washer
  • 347 Answers
When you had the water lines off the unit did you check the filter screens where the hoses screw on? .Their are screens in the washer inlets to keep crud out the washer.These screens can be carefully removed cleaned and reinstalled .The cold side is always the one to cause the problem because the hot side most of the crud has settled in the hot water heater If for some reason that did not fix your problem you will need to replace the inlet valve solenoid assy. Hope this Helps GOOD LUCK
Posted on Sep 04, 2010
  • 686 Answers
SOURCE: Cold water trickles, hot water fills fast as normal
where your water lines connect there is a sc reen inside and if it is clogged with rust lime and or mineral deposit. it needs cleaned out. you can pull it out with a ice pick or something pointy. Check your screen first and if that doesn't fix ya then yes replace the unit.
Posted on Apr 18, 2009
aasc
  • 1606 Answers
SOURCE: cold water trickles
Spring in water valve is weak . Replace water valve .
Posted on Jul 07, 2009
Testimonial: "Help was appreciated. I bought part at local appliance store. Had to modify slightly to fit different mounting hole pattern. Works great!"
jsrock516
  • 5911 Answers
SOURCE: Kemore 80 series washer - cold water fill is only a trickle
This problem may be attributed to a defective cold water solenoid on the water inlet valve. The following link explains how to access and/or replace:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
If you live in an area that has hard water, or if you use well water, sediment and rust can often clog the valve or sediment screens in the hose and fittings. You can attempt to clean the valve by removing it and allowing it to soak in a 50/50 solution of distilled vinegar and water. Submerse the valve fittings in the solution and allow to soak for 30 minutes. Do not get the electrical contacts wet, however. Rinse with clean water. Make sure you also check the ends of the fill hoses as well. Many of them have restrictor screens that can also become clogged.
If you wish to replace the valve, replacements can be purchased at searspartsdirect.com, appliancepartrspros.com, pcappliancerepair.com, or repairclinic.com. All these sites offer great service and competitive pricing, so shop around for the best deal. This isn't an expensive repair and its not difficult.
If you have questions, or need additional assistance, please let me know. I hope this helps you.
Posted on Aug 16, 2009
  • 8404 Answers
SOURCE: cold water pressure is very low
Do you have a regular "boiler drain" type valve for your cold water supply? Is it possible your washer came loose inside the valve like mine did?
You will of course have to turn off the water mail to check this.
Posted on Sep 07, 2009
  • 311 Answers
SOURCE: The cold water trickles. There
Sounds to me like your inlet valve is gunked up. You will need to replace your inlet valve. I would also check your hoses first to make sure the cold water hose does not have a screen on it that is full of calcium deposits. Hope this helps _MJ_
Posted on Aug 17, 2010
I replaced a moen 1222 valve stem becasue i had just a trickle of water. I go the new stem in ok, but still no water. I have the hot water heater diconnected on the water inlet, but the out let is still...
With posi-temp cartridges, if one supply of water, hot or cold, is interrupted, the cartridge automatically restricts the flow of the other water source. This is to prevent you from getting scalded if the pressure on the cold side drops because of a toilet being flushed or any other uses of cold water. The cartridge will only allow cold water to flow through if there is hot water to balance it out. If you restore hot water to the faucet, it will operate properly.
Aug 04, 2017 | Moen 2919 Chateau Two Handle Tub and...
I HAVE A SINGLE HANDLE HIGH NECK BLANKO KITCHEN FAUCET THAT IS RESTRICTING THE FLOW OF WATER WHEN TURNED IN THE HOT POSITION. THE WATER IS FLOWING FINE IN THE COLD POSITION BUT WHEN TURNED TO HOT...
If water come out the faucet hot line,check if is clogged.For this job you need to disassemble the faucet.
Here is a good PDF source to do it.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 12, 2010 | Blanco Classic Single Handle Faucet with...
Cold water trickles in tub. Hot water fine.
remove the cold water hose from the machine that is your service line feeding into it.
a screen in the inlet were the hose attaches to is probably clogged up
May 28, 2010 | Washing Machines
Slow cold water flow won't go back to full flow
I think the water inlet valve is nearly stopped up with sediment in the screen filter where the supply hose screws to the valve.Cut the water off at the hose and disconnect and look for the screen. The hot water usually doensn't do this because the water has time to settle everything out while it's in the hot water heater.
Aug 15, 2009 | Washing Machines
Cold water trickles
Jul 06, 2009 | Kenmore 22422 Top Load Washer
Hot water just trickles in both of my Kenmore top loader washers
Try reversing hot for cold hoses and see what happens. That will test your valves, hot water pressure, etc. As far as I know, the valve screens are right where the hoses hook up.
Apr 30, 2009 | Kenmore 22422 Top Load Washer
Apr 18, 2009 | Kenmore 23822 Top Load Washer
Moen Kingsley roman tub- no/slow hot water flow
sounds like you may have a little debri on hot side stem or kinked hose between valve and spout turn off water to house remove handle pull bonnet and remove stem turn water back on with stem removed see how water flow is be careful turning water on you could make a mess i am assuming the low pressure is in shower only
Apr 13, 2009 | Danze D302521 Antioch Roman Tub Faucet...
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
