Question about Technics Audio Players & Recorders
28 yr old Technics SU Z45 amp. Loses/lost right hand channel sound. Speakers fine so must be amp. Dunno if it is the wires connection at the back or something gone inside.Can it be repaired? Thanks. Paul.
  • Technics Master
  • 5,487 Answers
If you have lost the channel on all functions IE:tape, radio, aux etc. Then there's nothing wrong with the back connections. The good thing about stereo amps is that it uses the same parts for one channel as it does for the other. Which in your case means that the left channel can be used for a guide to the right. The first thing to do is look around the amp. Find the two channels parts and compare them, first by looking at them. If you find one burnt and the other good, you have solved it.
As long as you keep away from the power supply parts, you can touch them with an insulated screwdriver. A buzz means it's working and if you work backwards from the speaker section, poking parts with the screwdriver you should be able to find the cause of the problem. Remember use the left channel as a guide to what happens in the right.
Posted on Sep 04, 2010
Testimonial: "Many thanks for the advice!! "
How do i hook my speakers to my amp
Your amp has separate outputs for rear channels. Simply connect your rear speakers to the outlets on the back of your amp set up for them.
Jun 11, 2015 | Technics SU-G75 Amplifier
Technics su-z65
Hello
Your Tchnics is too old model and it has power transistors are used in output section. The output power is rated as 50Watts/channel/4Ohms. You can connect extra speakers to this left and right outputs, such a sway that the impedence should not go bellow 4 Ohms. Its repair book informs me that if any of the output transistors has gone out, it will not be available any more, and no substitutions cam be done. So be care when connecting more speakers. OK.
Jan 06, 2012 | Technics Audio Players & Recorders
Hi I just got a Technics SU V2 amp and can't get sound from the speakers. What size speakers would suit this amp? What is the correct method to connect the speaker leads to the back of this amp,...
Being a 500W amplifier, you need to connect speakers with 300W each. The correct method to connect speakers is red terminal of speaker should be connected to red terminal of amplifier & black to black. The left side to left side speaker & right to right speaker. There may be main & remote terminals. Main speakers are the speakers at local place of the amplifier & remote for remotely placed speakers. I do have Technics SU-V85A which is somewhat similar. Enjoy! A nice piece to listen.
Oct 22, 2011 | Technics SUV500 2-Channel Amplifier
I have a technics SU-v500m2 amplifier connected via the aux input to my pc, i wish to link another amp to the same input, is this possible, and if so how?
Let's establish which is the IN and which is the OUT here. The PC is a Line Level source so its OUTPUT would feed one of the amp's Line Level INPUTs.
What's the second amp going to do in your scenario? Something other than the normal stereo channels; something multichannel (if your PC supports it); or just more speakers supported for the PC to feed?
An RCA Y-connector pair would share the stereo output of the PC with multiple Line Level destinations.
If a second amp with its own volume control is intended to share the same two channels with the SU-V500 it could also be slaved off the back of the SU-V500 wih an RCA patch pair exiting the Tape 1 or 2 REC(OUT) jacks. The second amp would receive full-volume audio from whatever source the SU-V500 is playing. Just don't activate the selected Tape monitor on the SU-V500 or you will cut off the source to both amps.
Sep 24, 2011 | Technics SUV500 2-Channel Amplifier
Hello I have a Technics SU-V45A amp, it's about 18
See there is a problem with the volume conroller as it is 18 years old the controller has worn out replace the volume controller with a new one and you will be able to enjoy great sound again
Dec 05, 2010 | Technics SUV500 2-Channel Amplifier
Su-v55a technics amp cuts off when volume up to 2
usually meens it is protecting itself from destruction
check your wires and speakers for problems
Feb 09, 2010 | Technics SUV500 2-Channel Amplifier
Lost left stereo channel from amp. All speakers / wiring ok Technics SU-V6 amplifier. Wondering which component is most likely problem so I can cannibalise another amp.
If at full volume with the balance cutting out the right channel you can hear some music on the left (very weak), then the pre-amp is working and it's the power amp that's gone. Vice-versa if you can't anything, but say hum.
If it is the power amp check out the devices on the heat sink.
Check too for broken or burnt parts too!
Jan 21, 2010 | Audio Players & Recorders
Technics SU-G91 Left channel bad
Did you ever find the solution to the left channel issue? I have the same problem with mine.
Dec 02, 2007 | Technics SA-AX540 Receiver
Technics SU-V460 Amp Problems
Hi There, you need to eliminate all the connection and surplus items around the SUV-460 amplifier to determine if its the amp or not..
That is disconnect every thing then connect just the speakers and an input to the amp like a CD player or radio input. Then see if the amplifier plays OK thru the speakers on both channels and the balance control works fine....If it doesnt then the fault is inside the SUV-460 but if it all works fine than start reconnecting theemixer panel carefully and recheck all your cables and connections. Its a process of elimination to determine if its a "Box" fault or a cable fault...
Cheers From YUBEUT
Nov 14, 2007 | Technics SUV500 2-Channel Amplifier
621 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
