Question about Vacuums
I borrowed the Electrolux Epic Floor Proand the owner does not have the manual. I need to know how much soap to put in and I cannot find the power switch. Please Help! Thanks, Dana
  • 694 Answers
Use 1 tank cap of Home Styles Turbo Shampoo by Aerus for each line of water. There's a clear strip on one side of the tank that has marks. If filled to the first mark, use 1 cap of shampoo. Second mark, 2 caps, etc.
Ensure you use the black bristle brushes.
You can download the manual in PDF format from the following site:
http://www.aerusvacuums.com/support/manuals/
The Floor Pro is listed in both the current and older model sections; just click and download/save to file of your choice.
Posted on Sep 05, 2010
I need a operating manual for EPIC 6500 Model 1763
You can download the manual from the Aerus/Electrolux site.
http://www.aerushome.com/Site/Manuals
I hope this isn't too late.
Jan 15, 2016 | Electrolux Vacuums
Need instructions for a Electrolux Epic floor pro Heavy duty carpet shampooer
go to www. electrolux.com and download your model.
God bless you
Jun 20, 2012 | Electrolux Floor Pro Vacuum
I would like to know how i get the very bottom piece off my vacuum off so I can put a new fidder hose on it? The hose is black and it is only about six inches long. its lacation is on the very end of the...
You don't have to take the vacuum apart.
Assuming this is an Epic 3500 or similar upright Electrolux:
1. Lay vacuum on it's side.
2. Gently pull hose from power head. It's not screwed in so that should be easy.
3. Unscrew it from the upper portion of the machine by turning the hose clockwise. Turning counterclockwise tightens it.
4. Remove it.
5. Screw one end into upper portion of vacuum by turning counterclockwise.
6. Insert other end of hose into opening in power nozzle. Some manipulating may be necessary for proper fit, but this is all that's needed.
Sep 22, 2010 | Electrolux Epic 3500 Vacuum
I have the electrolux vacuum epic series 6000 SR and bought it used therefore I dont have a manual. I have had it for about a yr and it worked great..it looked like it should have a filter but I didnt...
1. A manual can be downloaded from:
http://www.aerusvacuums.com/support/manuals/.
The Epic 60006500 is located under "Older Models". Download the Epic 6500 manual
2. Check for clogs in the hose and the power nozzle inlet.
3. Disconnect hose. Turn on vacuum. Does it run? If so, place hand over intake? Did it shut off? If it did, the problem is a worn out or broken component inside the vacuum. Generally a result of using generic "made to fit" Electrolux bags. This is a part that needs to be replaced in an authorized Aerus (Electrolux) shop.
Sep 15, 2010 | Electrolux Epic 6500 Vacuum
I need a users manuel for my Epic floor pro floor shampooer model # S1058
The manual can be found at http://www.aerusvacuums.com/support/manuals/index.cfm.
You can go to either "Current Modesl" or "Older Models" and select the Lux Floor Pro. These are basically the same machines as yours.
Jun 21, 2010 | Electrolux Floor Pro Vacuum
I am looking for an owners manual for my Epic Series 6500 SR.
Owners manual in pdf-format Electrolux Epic Series 6500 SR:
http://homeappliance.manualsonline.com/ex/thread/view/idThread/1424472
Clicking "Epic6500.pdf" will pop up a registration shortly,
but the manual appears directly after that.
Aug 09, 2009 | Electrolux Epic 6500 Vacuum
Electrolux Epic 6000 SR Owners Manual?
oh, and as far as i know there's no secondary filter on this machine. or at least if there is, ours hasn't needed any tending to in at least ten years or so...
Jan 05, 2009 | Electrolux Epic 6500 Vacuum
My Electrolux upright worked fine
Are you using the proper bag? There's a kill/reset switch that needs to be pushed down by the rim of the bag before the unit will run.
Jun 22, 2008 | Electrolux Epic 6500 Vacuum
Electrolux Epic 6500 Power head
Call your local Aerus repair shop.
Feb 27, 2008 | Vacuums
Owner's Manual
Apparently there was a split in the company and many repair manuals are under the company Aerus. http://www.aerusonline.com/service/manuals.cfm
Apr 28, 2007 | Electrolux Epic 6500 Vacuum
Vacuums Logo
61 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
