Question about Sewing Machines
I cannot get the sewing machine bobbin casing back into the machine. When I put the bobbin in, the casing pops out. Can you help me? I have a 9410 Singer Sewing Machine.
    Genius:
  • 1,788 Answers
Do you think that it is broken? You can go to www.sewingpartsonline.com and find a new case for $11.99-$13.99. The reason I say this, is because I faced a similar problem a few years ago, I was shocked to find out it was not something I was doing wrong but that it was broken. Take alook at this site and you will see each part for the bobbin case and maybe you can determine if this is the problem
Posted on Sep 13, 2010
Testimonial: "Yes, I looked and the edge of the plastic piece was broken. It makes me wonder WHY they use plastic. Things like that never last. Thank you!"
The bobbin housing in singer model 9410 keeps moving out of position
After you put the bobbin case in, release it, and then pull on it to make sure it is in correctly.
The gathering is called a "bird's nest", and is caused by the machine not being threaded correctly.
Rethread the machine top and bobbin.
Then, sew a test stitch on a scrap of like material.
Apr 08, 2013 | Singer Sewing Machines
Metal Bobbin Case falls down in machine when I try to sew
the bobbin case needs to be checked to see if it needs to be replaced
and also checked the hook and hook race.
Feb 16, 2013 | Sewing Machines
I have a singer 7468. THE BOBB IN CASE KEEPS POPPING OUT. CAN THIS BE FIX?
the sewing machine may need a new bobbin case,, but I would
suggest take the sewing machine to a repair shop to see if there
is something wrong with the hook & hook race,,that may be why
the bobbin case is coming out.
Oct 06, 2012 | Singer 7468 Mechanical Sewing Machine
Singer 9410 Bobbin Repair
it sound like the machine needs to be serviced by a sewing machine repair tech
Jan 28, 2012 | Singer Sewing Machines
HOw did you put back the bobbin in a singer 9410
all you wanna do is open the plate of your machine, there is a hole, insert your bobbin there.
Mar 14, 2010 | Singer 8280 Mechanical Sewing Machine
Sewing machine bobbin casing is loose and can't get it back in!
In the lower right hand corner of the bobbin case area, there is a small finger-like spring structure. Gently lift it and push it to the right. Take the bobbin case in hand and inspect it. It is a round piece of metal with a groove running down the edge of it. Now look at the hook, or the round piece of metal that is in the bobbin case area. It has a slight shelf-like structure. Place the bobbin case groove into the shelf-like structure in the hook so as to make it sit flush. With your finger, take the front of the bobbin case and push it to its left so that it is as far counterclockwise as possible and replace the spring.
Hope this helps.
Jul 20, 2009 | Yamata FY700 Mechanical Sewing Machine
Can't put the plastic bobbin holder back into position
make sure the needle is all the way up and the bobbin is in the case the right way. check to be sure there is no lint or dirt impeding the case. you may have to take out the piece the case fits into to do this. i have found this to be the problem more times than not.
May 11, 2009 | Yamata FY700 Mechanical Sewing Machine
Singer 9410 Bobbin
Update:  Today I took my machine in to get serviced - they replaced the metal bobbin I was using with a plastic one, that was a little less rattley inside the bobbin case, replaced the needle with a new, universal one, and changed out the thread with something a little higher quality.  They also adjusted the spring holding the bobbin case slightly, and now it seems to work fine.  I'm not sure how long it will last, but for now I'm good.
Oct 02, 2008 | Sewing Machines
Singer 9410 Bobbin
I had the same problem and after looking on here and finding no answer I went back to my machine and found out what the problem was...ok, where the bobbin case sets in,the metal plate beside it needs to be fitted right close to the bobbin case, so loosen the screws(just two of them) that are in the plate(DO NOT REMOVE JUST LOOSEN) and slide the metal plate over some just enough to fit snug...NOT TOO TIGHT... if its seems to sew too tight loosen it a bit It worked for me, GOOD LUCK
Nov 11, 2007 | Yamata FY700 Mechanical Sewing Machine
Sewing Machines Logo
211 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
