Question about Keurig B60 Coffee Maker
My keurig just stopped working. No power. Tried plugging and unplugging it.
2 Suggested Answers
nathanieldso
  • 42 Answers
SOURCE: platinum keurig no power
under the warranty they mist give you a new one
Posted on Apr 10, 2012
I have a Keurig office pro coffee maker. After a power failure it will not work
Have you tried rebooting it like a computer? Unplug the cord and wait a bit then plug it back in? If that doesn't work the power spike of the outage likely damaged your computer board in the Keurig.
Aug 17, 2016 | Keurig Coffee Makers & Espresso Machines
I have a Keurig coffee maker model 155, very nice machine. However, it will not power up and work after a power failure. Is there some special reset button on this machine, perhaps?
I had a similar experience and had to dump the water, empty the coffee capsule and leave it unplugged for an hour. Make sure that ( if you have GFCI outlets) that they haven't tripped. After an hour plug your machine in and it should work as normal. Make sure that your cup sensor isn't blocked after all that cleaning.
Aug 17, 2016 | Keurig K-Cup Keurig OfficePRO Premier...
I have a Keurig 2.0 when you plug it in the power button comes on, on the lcd screen but when you touch the power button nothing happens. It won't turn on. Any suggestions. Thank you.
Found the below from this site: http://coffeestylish.com/keurig-problems/
Keurig 2.0 won't turn on
To turn on your Keurig 2.0 plug in the brewer, then press and hold the power button (the power icon will appear in the bottom right corner of the touchscreen). You should see a welcome! note. If it doesn't turn on you can do few things:
Check to make sure that the brewer is plugged securely.
Unplug and plug in the brewer.
Plug the brewer into a different outlet.
As a last step, Keurig even recommends resetting your home's circuit breaker just in case.
If nothing works, then you should definitely call Keurig customer service.
Jan 24, 2016 | Computers & Internet
Platinum keurig no power
Apr 10, 2012 | Keurig Platinum B70 Coffee Maker
My keurig b70 coffee maker says prime. sounds like the pump works for awhile then stops. prime lights up on the screen and doesnt let me do anything else why
Mine would brew the first cup fine, then the pump would run but would not draw water from the reservoir. I turn it off, turn it back on it would draw water for one cup then would not draw water again. I unplugged it waited 30 seconds and plugged it back in, assuming that would reset the electronics. It worked fine following the PDPU (power down, power up) procedure. Simply turning it off will NOT reset the processor, you MUST unplug the unit. Remember to wait 30 seconds or so prior to plugging the unit back in.
Nov 28, 2011 | Keurig Platinum B70 Coffee Maker
LED Display window is blank
try pressing all 3 size buttons down and then with them down press menu, wait then unplug and wait 10 seconds or so then plug in and it should have re booted.
Jan 04, 2011 | Keurig B60 Coffee Maker
Blinking lights
let it blink for about 15 minutes, then adjust each one of the settings, then turn it off and back on, for some reason it stops flashing and will work. Warning, after doing this for about a week, mine now has no power at all. It is plugged in and the outlet works and there is no power going to the machine, it is not even a year old!
May 20, 2010 | Keurig Elite B40 Coffee Maker
Keurig B60 Coffee Maker Logo
947 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
