Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Vertical output IC
Can you tell me where to find the vertical output IC?
  • 121 Answers
It's on the main board which is the board all the way on the right side and attached to a small heat sink
Posted on May 12, 2008
How to solve horizontal lines on a CRT TV monitor and what could be the possible courses for it
Monitor horizontal lines problems usually caused by a defective vertical output/driver ic. A missing supply voltage to the vertical output ic may caused similar faults which is one horizontal line across the display. Dry joints and missing vertical output pulse from vertical oscillator ic also could contribute the same symptom. If you discovered that the protection resistor (usually from 1 to 4.7 ohm) open circuit or burnt, then replacing it won't solve the problem. The resistor burnt or open circuit was due to a short in the vertical output ic. Thus you have to replace the vertical output ic and the burnt resistor together before you switch on the monitor.
Jun 12, 2015 | Televison & Video
Where is horizontal scan out put section?
Hi Majid
Just contact any service technician to repair your TV. It will be best for you.
Gopakumar Gopalan Google
Feb 01, 2015 | Televison & Video
Where is horizontal output ic in my t.v?
There is no horizontal oscillator IC. The horizontal oscillation is generated and outputted by the main system control IC LA76810 itself. Refer some circuit diagrams using LA76810 to get more details about the horizontal oscillation output from the IC. Measure the frequency at that output pin. It should be some ever near 15.62KHz.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the IC number, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Jan 31, 2015 | Televison & Video
Why come white vertical line on my t.v screen in center?
You said "I checked vertical output line from main ic pin 23 found correct"
But the problem is "Horizontal Output Line" Try that.
Jan 29, 2015 | LG Televison & Video
What is the frame output ic
Hello
Frame output IC means nothing, but the VERTICAL OUTPUT IC. Every TV will have it, which will scan picture vertically at 50 or 60 Hz. [1 HZ means one frame per second. Normally TVs will have 50Hz, 60Hz and 100Hz vertical frequency]. As vertical frequency rat increases, the picture fliker wil decrease. High level high-cost TVs will have 100Hz or even more frequency will be used for vetical scanning.
In the case of computer monitors, the vertical frequency will vary from 60Hz to 120hz. You can see its picture stability, at this high frequency.
The IC [Integrated Circuit Chip], which generates the vertical frequency and outputs it called the vertical output [frame output] IC. OK
Wish you a Proseperous and Happy 2012.
Gopakumar G, Trivandrum City, Kerala State, South India.
Dec 29, 2011 | Televison & Video
Unit has sound, no vertical deflection. caps and output ic ok. have b+ to output. nothing at pin 2 of output ic.
If there's an audio,,it might be the defective Vertical IC...but check first if there's 24v-26vdc supply coming from FBT going to Vcc of Vertical IC.
If there's no Audio,and only white horizontal line in the screen,check the Vertical out of Jungle IC.
Oct 12, 2009 | Toshiba 27D46 27" TV
Emerson EWF2702 TV Problem
Hello yyimerr1,
This is a vertical deflection problem, These are the possible causes:
1) bad vertical coupling capacitor
2) bad vertical output IC
3) bad vertical driver IC
4) bad CRT deflection yoke
Troubleshooting needed:
1) using the TVs schematic locate the driver IC the output IC and the CRT yoke transformer.
2) using an oscilloscope look at the vertical driver signal it should be a sawtooth signal from the driver to the yoke (increasing in amplitude for each section, i. e. driver and output).
3) if no sawtooth patter is seen that is your problem, look for the component in the section where signal is entering but nothing is coming out.
4) replace the components
Now let me tell you something, don't continue to play the TV with the line present with brightness applied, this will burn the image of the line into the phosphorous coating of the CRT.
I hope this helps
Thank you,
Shuttle83
Nov 01, 2008 | Emerson EWF2704 TV
TV
The vertical output IC has stopped working. The vertical output IC is the part that drives the coils in the yoke that spreads the picture up and down. This could be because it has cracked loose from the board (solder joints) or it simply burned out. Sometimes a bad pump-up cap will cause the vertical output IC to short out, and when the IC shorts out it often opens up a small value resistor next to the flyback. This is a relatively easy thing to repair. A qualified tech will be able to tell exactly why the vertical output has stopped working and repair it for you.
Aug 25, 2007 | Sanyo AVM-3659S 36" TV
Television has no picture
That TV uses the PTK195 chassis, and the fact that you see only a thin line for each color near the bottom of the screen tells me your vertical output IC has stopped working, and is putting a small DC voltage across the yokes. I have seen this caused by a defective vertical output IC and I have also seen vertical problems caused by a small CRT coolant leak which drips onto the main board near the vertical output IC. If you do not have experience servicing the PTK195 chassis than have a qualified tech handle it for you.
Jul 12, 2007 | RCA P52937 52" Rear Projection Television
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
35 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
