Question about Schlage B362 619 KA4 Dbl Cyl Deadbolt Per 004 Ea
Key keeps spinning in lock. - Schlage B362 619 KA4 Dbl Cyl Deadbolt Per 004 Ea
How can i remove gas cap if it just keeps spinning
Break it apart with a large pair of channel lock pliers like ones in picture.. 9_14_2012_7_12_41_pm.jpg
Sep 14, 2012 | 2006 Nissan Quest
When I attempt to use the key to unlock the driver's side door the key just spins
there is a linkage rod on the back of the key cylinder it sounds like it fell off
Aug 14, 2012 | Dodge Stratus Cars & Trucks
Bosch exxcell 7 washing machine (1400) Power cut at home. Display now shows key symbol - 12 minutes 1200 spin speed Have tried unplugging. Controls will not reset
Hi hulley3,
Keep the Start Button Pressed in for 5 sec.
If it does not help, try keeping the Power button in for 5 sec.
Should reset Child Lock.
Regards :-)
* If you found this solution helpful, please rate it
Jul 08, 2011 | Bosch Washing Machines
Remote won't unlock car. Not sure if it's frozen or battery dead. Drivers door won't unlock with key - it just spins around. there is no passenger lock. There is no key slot on trunk. I thought those...
There should be a key slot in the trunk emblem, or the emblem will spin to reveal it. If the key just spins it needs a new door lock cylinder. You can see my previous solutions for how to remove it.
Feb 04, 2011 | 2004 Volkswagen Beetle
1999 Ford Taurus. Can see crankshaft spinning fine coming out of block. Nut on end holding harmonic balanced spinning fine too. Harmonic balancer doesn't spin. How to fix? Do I need to pull the engine to...
There is a key way in the crankshaft and the balancer with a woodruff key that keeps it locked in place. The woodruff key resembles a half moon shape. You will have to remove the balancer to see what kind of damage there is and go from there.
Jan 02, 2011 | Ford Taurus Cars & Trucks
1997 bmw 328i ignition lock just spins around, i need the tumbler fixed. are there other bmw years that are interchangeable? I don't mind using two keys, one for ignition or one for doors. I don't care...
There is nothing wrong with the lock,,,it is suppose 2 spin around if you do not put the key in correctly.
My 1997 bmw does the same , it is a security measure incase someone breaks into the car and tries 2 steal it by putting a screwdriver in the ignition ,,it just spins.
before putting yr key in the ignition, move yr steering wheel slighty so its not resting on the steering lock , put yr key in and turn , it does not spin
Sep 14, 2010 | 1997 BMW 328
Maytag neptune washer keeps beeping
The Service Manual for reference. Sears Parts Direct for reference.
I have tried to work with a few folks on this issue never received feed back to resolution see this post. I feel the issue is caused by one of three possible issues.
A stuck key issue/defective Spin Cycle key making constant contact forcing the Key/LED to cycle thru the Spin Cycle settings. Under normal conditions if you press and hold the Spin Select key it will cycle thru the settings, yours has a mind of its own (defective issue).
A false signal from the Control Board for the Spin Cycle.
A corrosion path issue at the Membrane Pad ribbon cable socket connection between pins 5 and 4. See page 20 of the SM button functionality “Spin” key.
Try to verify that the spin cycle membrane key is not stuck/defective signaling the Control Board to cycle thru the spin settings. I have not experienced this issue but let’s try the Membrane Pad Test to get a start point. See the Service Manual page 15, I have modified the process to make it a bit more understandable at least for me. Make sure the two digit display is not On or Lite.
Press the off button first so there is nothing displayed in the Two Digit display of your FAV6800AW.
Now Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin Only keys for three seconds or until the control beeps. While in Service Mode, pressing the Presoak key will start a membrane switch check that verifies switch operation.
All the LEDs (except Presoak ) can be toggled or slewed by pressing the key associated with the LED or set of LEDs. Do not press the Presoak again during this test.
Press each key once and only once including the Signal Key the on side and the off side, also the UP and Down Arrow key of the LED display. All keys (including the OFF button) must be pressed within 5 minutes for this test to pass. “PA” will be displayed for five (5) seconds once all keys have been pressed and the test is completed (more like PA will be displayed for only a few seconds on my FAV6800AW). Following 10 seconds of inactivity at any point, this test will exit without any display. Let us know the results.
See my additional comment this board has message limit issues.
Sep 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
TURNS OVER
TRY TO BANG ON THE BOTTOM OF THE GAS TANK WHILE SIMULTANEOUSLY TURNING THE KEY SWITCH TO THE ON POSITION, WITH A GOOD FUSE IN THE FUSE PANEL, THIS SHOULD JAR THE PUMP ENOUGH TO HELP IT SPIN. IF THIS DOESN'T WORK AFTER THREE TRIES, THEN REPLACE THE FUEL PUMP AS IT HAS LOCKED UP. HOPE THIS WORKS FOR YOU. KEEP ME POSTED PLEASE. BEST OF LUCK TO YOU.
May 01, 2009 | 2000 Plymouth Neon
Schlage B362 619 KA4 Dbl Cyl Deadbolt Per 004 Ea Logo
975 people viewed this question
Top Schlage Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Schlage Measuring Tool and Sensor Expert? Answer questions, earn points and help others
