Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
How do you remove the head (line,string) holder from a ryobi weed eater, the old head is worn out and seems to be pressed on with a clamping washer to the shaft. I does not appear to unscrew like most weedeaters.
panilling9
  • 284 Answers
SOURCE: remove head to restring
you need to locate the black knob at the trimmer head and turn it coun ter clockwise and remove it to access your string spool you may have to chase the knob with pliers because some are more than hand tight
follow arrow on the spool for line winding direction
Posted on May 26, 2009
Healeyman
  • 1198 Answers
SOURCE: ryobi weed eater will only run if i hold the choke down
Mine won't spin up till it is good and warm. Check the end of the fuel line in the gas tank to see if it is clogged or dirty or slimey. Make sure the end has not fallen off.
Posted on Apr 30, 2009
connertamago
  • 37 Answers
SOURCE: I have a Ryobi Reel Easy bumb feed stringhead on
what model is trimmer? cs30? if you found the line on it clockwise, that's your problem. on the cs30 it rotates counterclockwise if youre looking at the head while trimmer is upside down. the line has to be wound opposite direction or your going to have a MESS of string in the head.
Posted on Jun 01, 2009
  • 148 Answers
SOURCE: My ryobi weed eater is idleing ok, but pulsates at
Have you tried adjusting the carb settings?
Posted on Jul 13, 2009
canbruce75
  • 1776 Answers
SOURCE: I have a ryoby 31cc weed eater I need a diagrm on
Typical fuel line routing2.gif is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Posted on Sep 25, 2009
Weed-Eater
head is more than likely worn.try replacing
Jun 15, 2013 | Garden
Change head on trimmer
you buy spool of line and thread your self, you maybe able to buy the spool already has string on the spool, most are basic, the spool should have the direction you need to string it.unplug the trimmer, turn up side down, it have nut on it, unscrew it counter clock wise, than pull spool off restring the line for the weed eater, the string must be wound counter clock wise from the direction the weed eater or trimmer spins.
www.ask.com/mfg.name/make/model/change/head/trimmer/
Mar 21, 2013 | Troy-Bilt 25 CC Gas String Trimmer TB22EC
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 | Garden
Remove head to restring
May 26, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a Ryobi Reel Easy bumb feed stringhead on my Cs30 Ryobi weed eater with an expand it curved attachment. Loading the replacement string is no problem, but getting it to come out is another problem. I...
May 13, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Screw cap to reel head of ryobi ss30 weed eater will not come off
The spool retainer nut loosens when you turn it clockwise . The opposite of " normal ".
Apr 05, 2009 | Garden
Ryobi weed trimmer
I have one of this trimmers. It is simple to replace the line.
-First line up the arrows on the bottom of the spindle.
-Then feed the line back in one of the holes in the side of the spindle (this is the same hole that the cutting string comes out of).
-You will see the line come out of the bottom of the spindle.
-Take that line a place it in the hole on the bottom of the spindle.
-Leave about 9 feet of string hanging out of the weed eater (do the same with the other side).
-Then turn the inside wheel (I can't remember if it is clock wise or counter clock-wise but it will only turn one way) most of the string is rolled into the spindle.
-Cut the string of about 5 inches out of the weed eater. You're ready to cut!
May 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
64 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
