Question about Nuova Simonelli Microbar Espresso Machine
Flowmeter warning comes on each time i press the coffee button. The coffee grinds and the pellet is expelled, but there is minimal, sometimes no water out of the nozzle. loud grinding noise. Could my internal water line be pinched or clogged, where do i find it?
No coffee will come out
Maybe the coffee is down, around the waste container. In this case the grinder must be opened probably the cofee funnel is jammed or is not in his place to direct the grinded coffee.
Jul 29, 2014 | Saeco Odea Giro Plus Coffee Maker
Window shows "Expel Air" message.
Fill the water tank.
- Turn the program selector to "On with
light" and place containers below the
hot water dispenser and the steam
nozzle.
- Press the hot water button, turn the
steam selector counterclockwise
and let water run out until it streams
steadily.
- Press the hot water button again.
Turn the steam selector to "o" to shut
off the water.
ENJOY YOUR COFFEE
Jan 15, 2011 | Miele Coffee System
One side of the machine works properly however the right side does not expel water.
That could be one of 3 things;
1 - the brew solenoid is blocked or not working.
2 - the metering jet at the top of the head is blocked.
3 - the flowmeter is blocked.
Nov 11, 2010 | Astoria Argenta SAE-2 Espresso Machine
My saeco machine is not functioning in the right order, it grinds after it makes the pad. So I first hear the clicking sound (meaning it is making the pad first with old grinded coffee) and then it grinds...
HI
Read the first then go to the bold letters.
To program your Magic Dlx: Press and hold the steam and small espresso buttons at the same time, then push the energy saving button (top right). Water Hardness. The large coffee button programs the water hardness. Press the button once and you will have one light in the top row, left side. Press it again and you should have two lights lit. Press it three times and you have three lights lit. Four and you have four lights lit. Press it a fifth time and it goes back to one light. Each light represents your water hardness. So if you have a water hardness of 3, press it until you have three lights lit. Press the energy saver button to exit the program and save your hardness level in the machine’s computer. It will now tell you when you should descale your machine. Pre-infusion. Press the medium coffee button to activate and you should see the light come on. Press the button and turn the light off to deactivate the pre-infusion. Pre-grinding. Pre-grinding is turned on with the cup warming button. When it is lit, the pre-grinding is on. Press the button to turn it off.
Nov 14, 2009 | Saeco Magic De Luxe Espresso Machine
Coffee does not come out when I press the small coffee button. The coffee grinds but water is not injected. The large coffee button works.
Hi
Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button.
Nov 01, 2009 | Saeco Incanto Classic Espresso Machine
No coffee coming from machine
Can you make a cup of water or you can only get a half cup?
I think it can be your flowmeter in the machine that has to be replaced.
Aug 02, 2008 | Saeco Magic De Luxe Espresso Machine
Meile espresso maker does not expel air
Press Hot Water and Steam Button at same time.
Dec 24, 2006 | Miele CVA615 Espresso Machine
Open Questions:
See all Nuova Simonelli Microbar Espresso Machine Questions
Nuova Simonelli Microbar Espresso Machine Logo
52 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
