Question about Sanyo AVM-2759S 27" TV
Horizontal Line Was playing GH 3, switched over to DVD and all of a sudden the picture turned in to a thin line across the center....8 years old...should I fix it?
  • 4,234 Answers
This is a problem with the vertical circuit. Look for a small flat IC attached to a heat sink. It should have about 9-11 pins and be marked LA7838 or something similar. Try resoldering the pins first. If that does not resolve the problem, replace the IC. The IC will cost between $10-$20.
Posted on May 12, 2008
Thin horizontal line across the screen
you need to replace the electrolytic capacitor in the horizontal section of of your tv sets,cause the capacitor is weak.need to repair
Jan 11, 2009 | Sharp 27C-240 27" TV
Line across top of screen
Hey I had that same problem with my sega genesis,on my 52 inch rca hdtv,,its because your using the antenna plug to plug it to your tv,,look on ebay youll find for like 3 or 4 $. a s video for your genesis ,,no more lines ,, way better picture,, very clear,,hope to help,,, thanks
Jul 02, 2008 | Sega Genesis Console
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Thin horizontal line, Panasonic TH-50PX60U
unfortunately the panel is bad. I've worked on a number of these panels to know that symptom. I checked with panasonic and the warranty is one year parts and labor. you may be able to get panasonic to fix it if you still have warranty (purchased within 1 yr.) or check with your state's implied warranty. you might qualify for warranty repair under this implied warranty. call panasonic when you find out about the state's rules.
Mar 16, 2008 | Panasonic TH-50XVS30U 50 in. Plasma HDTV
Horizontal line (with about an inch of picture)
check a capacitor on the horizontal section
Oct 28, 2007 | Toshiba 27AF43 27" TV
LG colour TV RI32CZ10RX problem with picture
My LG tv has suddenly got a problem with the picture. Whilst watching the tv with no problems at all, the picture was suddenly reduced to a thin vertical line down the centre of the screen and an awful smell seemed to come from the tv There is a short ckt in your tv in horl. section. 1 isolate power from horizontal section. 2 check for normal output from power supply. 3 check parts in horl output section a hor.output transistor b diode & cap in h/output trnsformerckt. c check for print. d if all are ok check for eht transformer. e if every thing becomes then reconnect hor output section supply. f put on the set.
Sep 23, 2007 | Televison & Video
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
My picture is black except for a thin horizontal line
hi When you let the line to long it will burn in!! you need to look into the VERTICAL output section. Most notably check the solder joints on the vert output IC and ESR the caps. If you don't know what any of that means, then take it to a professional. good luck
Feb 20, 2006 | Hitachi 36CX39B 36" TV
Sanyo AVM-2759S 27" TV Logo
100 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
