Question about Xirlink Stingray USB Webcam
Can't install camera on windows xp - Xirlink Stingray USB Webcam
Im having problem with my loptop...i installed windows xp and now i cant use my camera... how can i locate my camera... before i installed xp.. my original os was windows vista.. im wondering whats wrong...
did u install the drivers for the camera ,if not then download and install them.If you have a resource cd of the laptop then you can install the drivers from that cd.
Dec 09, 2010 | Systemax Neotach 3300 Notebook
IBM PC Camera driver for Windows XP
You need to get the driver for that camera for XP. Try this link and if not OK, google for another link:
http://www.xp-drivers.com/drivers/86/86443.htm
Oct 25, 2008 | IBM Webcam
Installing Hacker 8850 on Windows XP
were do i get hacking stuf how do i install it HELP
Nov 28, 2007 | Tamarack Hacker 8850 Digital Camera
3350 digital - i lost the c.d that come with it
Windows XP should have the driver installed. Have you tried to attach the camera to your computer? If Windows XP does not recognize your camera, you may have to Google Premier Electronics for their Web Site.
Mar 26, 2007 | Premier Electronics DIGITAL PENCAM - 3350...
Can I use the PDC 1100 camera with Windows XP?
Yes, you can use the camera with Windows XP, but you will no longer be able to use a USB port to download your photos. Only serial port downloads are supported under Windows XP for the PDC 1100 camera. Follow the instructions below to reinstall the PhotoMAX software and camera drivers using Windows XP's Program Compatibility Wizard. 1. Insert the PhotoMAX CD-ROM in the CD drive. If the program begins installing, press OK to close the "not compatible with Windows NT" error message. 2. Start the Wizard by clicking the Start button and choosing All Programs > Accessories > Program Compatibility Wizard. Follow the on-screen prompts. 3. On the second screen, select I want to use the program in the CD-ROM Drive and click Next. 4. Select Microsoft Windows 98/Windows Me and click Next. NOTE: You may have to scroll down to see this option. 5. Uncheck the following items: * 256 colors * 640 X 480 Screen Resolution * Disable Visual Themes 6. Click Next. 7. Click Next again. The PhotoMAX software will begin installing. Follow the on-screen prompts. 8. Follow on-screen prompts to finish the installation and click Finish. 9. When the Compatibility Wizard asks if the program worked correctly select Yes and click Next. 10. When the program asks if you want to send information to Microsoft, select No and click Next to finish the installation. 11. Shut down and restart the computer. After the restart, you should be able to download photos using Windows XP.
Sep 14, 2005 | Polaroid PhotoMax PDC 1100 Digital Camera
Installing digital camera drivers from Nikon View 5 or 6 CD on Windows OS
This document assumes that your computer did not recognize your digital camera after you have installed Nikon View version 5 or version 6 (5/6) using "Easy Install" and then restarted your computer. Nikon View 5/6 compatibility: Windows 98 SE Windows ME Windows 2000 Windows XP Home Edition/Professional Note: Log on as Computer Administrator when installing drivers on Windows XP Home Edition/Professional or as Administrator when installing drivers on Windows 2000 Professional. Cameras that are not supported by Nikon View 5/6 Nikon View 5/6 does not support direct connection of COOLPIX 950, 910, 900, 800 or 700 digital cameras however it will support a Compact Flash card reader which contains images taken with these cameras. Before installation - Before installing Nikon device drivers, make sure the camera is disconnected from the computer. If the Device Wizard launches when you connect a camera, click Cancel to exit the Wizard. - You have turned off any virus-checking software that may be running. - You have exited all other applications. Procedure for driver installation First DISCONNECT THE CAMERA FROM THE COMPUTER and follow the instructions below. Insert the Nikon View CD into the CD-ROM drive, the Select Language dialog box appears. Select a language Select the language of your choice from the pull-down menu. After you select a language, click Next to display the Install Center window. Custom Install Step 1: Select the software to be installed. Select the programs you want to install from the list in the Custom Install tab. Step 2: Install the driver Choose the camera driver you wish to install and click Install. If you have chosen more than one program, the programs are installed in the order of display. - PTP Drivers Select this check box to install PTP drivers. This check box is only displayed if you are using Windows XP. - COOLPIX Camera Drivers (all models except 990 and 880) Select this check box to install the driver for COOLPIX series cameras (excluding 990/880). This check box only appears if you are using Windows 98 Second Edition. - Drivers for COOLPIX 990 and 880 Select this check box to install the drivers for the COOLPIX 990/880 - Drivers for D1 series cameras Select this check box to install the drivers for the D1/D1X/D1H cameras. Install PTP Driver (Windows XP only) Check that the camera is disconnected If you selected the PTP Driver, the installation of the driver will start. The Setup dialog box below is displayed, asking you to confirm that a camera is not connected to your computer. Make sure a camera is not connected, and click OK to begin installation. Windows 98 SE If you are using Windows 98 SE, drivers for all COOLPIX cameras (all models except 990 and 880) will be installed if selected. The dialog box shown right will be displayed. Click OK to continue. When you install the device driver, the dialog box shown below may be displaye
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Xirlink Stingray USB Webcam Logo
26 people viewed this question
Top Xirlink Computers & Internet Experts
micky dee
Mohamed Ismail
Mohamed Ismail
David
David
Are you a Xirlink Computer and Internet Expert? Answer questions, earn points and help others
