Question about Refrigerators
I HAVE A SERVIS PLATINUM UPRIGHT FREEZER. 3 INDICATOR LIGHTS - GREEN (POWER), FLASHING RED, YELLOW (FAST FREEZE). CURRENTLY FLASHING RED CONSTANTLY - WHY? BEST REGARDS, IAN MOLYNEUX
SOURCE: Hotpoint Fridge Freezer FF187e - 3 lights flashing
Thanks to this site and previous writers - my fridge freezer is working fine now.
My freezer was working normally but the fridge did not at all.I opened the back of the freezer section to reveal the filament all iced up as previously recommended ( many thanks) -rememeber there are 2 white covers to remove. PlEASE DO NOT chip away the ice as you will accidently chip the metal and break the filament . I did that once with another freezer and gas came out and therefore broke it- be patient and safer and use a hair dryer.
I am month 8 of 12 month warranty- should i contact hotpoint and complain what seems like a design fault? i would recommend feedback.
Posted on Apr 17, 2009
sodeep
  • 3267 Answers
SOURCE: Red alarm light is on on Westinghouse upright freezer
Most probably during transportation either the coolant(previously freon gas) may have leaked out so the pressure on the cooling pipeline causing the red alarm because the compressor will overheat if the fridge is kept running at very cold thermostat readings and no effect of cooling the fridge will ultimately result in the compressor getting burnt. However fist have look at thermostat setting knob which could have loosened during transportation and just pushed into the spindle without knowing the correct angle, thus even though it looks as if on high cool but could also be the lowest setting..........sodeep
Posted on May 19, 2009
  • 53 Answers
SOURCE: RED TEMP WARNING LIGHT ON MOTOR RUNNING
I'm sorry to have to tell you that this sounds like a very expensive fault to fix!
Either your fridge/freezer has degassed (lost the refridgerant gas) through a small leak in the pipe system behind or inside the freezer compartment, OR the compressor (what you called the motor) has started to fail.
Either way, these are very expensive repair jobs. It's possible to replace the compressor within about an hour, but if your model is out of guarantee, there will be around a £50/60 Call-out charge and the compressor will cost between £75 and £150 depending on the model.
Alternatively, if the fridge/freezer has lost gas, the engineer would have to try to find the leak - this could be IMPOSSIBLE if the leak is within the pipework inside the back of the fridge or above/below the freezer compartment.
I'm sorry to say that it's looking like you may have to part with a lot of money - or say goodbye to the fridge/freezer you have!
Posted on Nov 17, 2009
SOURCE: red light on Hotpoint Iced Diamond freezer
Got a Hotpoint Iced Diamond fridge freezer cant find model no but got red light next to green, light works in fridge but there is no sound of anything else working please help.
Posted on Sep 10, 2010
SOURCE: BRADA MF-305 UPRIGHT FREEZER AMBER/YELLOW LIGHT ON
I bought the same freezer and have the same question.
Anybody know? Did you figure this out vemmy?
Posted on Sep 27, 2010
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
Apr 11, 2013 | Zanussi 2.83 cu. ft. / 80 liter Upright...
Manual for lemair freezer model fr-120v
I have the manual.
From the Left:
(1) The "!" is the red warning indicator - indicates if the temperature is currently lower than set.
(2) "I" is the green power indicator,
(3) "S" is the Yellow Fast Freeze indicator,
(4) "S" is the Fast Freeze switch/button,
(5) "I" is the Off/On switch/button.
(6) - with the coin slot - is the Temperature Regulator.
(I have mine 1/2 way around the dial.)
Sep 18, 2012 | Refrigerators
Magic chef freezer temperature indicator light on, not usually on?
Is it a red light? If so it's not reaching temperature (the alarm is about -12c) If it's a yellow light, you've accidentally switched on "fast freeze". If it's a green light it's just the power supply light.
May 08, 2012 | Magic Chef 5 cu. ft. / 142 liter Chest...
Eurotek freezer why it does not freeze
i have a eurotek upright freezer. green light is a power on indicator ... reddish light is fast-freeze mode ... i have a copy of the manual... if you have additional queries, you can reach me at citizen_jdc@yahoo.com.ph
thanks
Aug 03, 2010 | Frigidaire FRS23KF7AB Side by Side...
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Aug 21, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Servis frostfree fridge freezer
Hi, I had that last year - It was the control board!
Oct 24, 2008 | Freezers
Servis fridge freezer mo330al lights
Hi there
  • Green = Ready (Power ON)
  • Amber = Super Speed Freeze
  • Red = Warning overheating or fault.
Hope this helps
Thanks J
Jan 04, 2008 | Freezers
Refrigerators Logo
88 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
