Question about KitchenAid KUWA244PBS Wine Cooler
Light is on power is on but wine cooler not cold! No sounds from compressor.
Light is is on but comp. not running no sound
Posted on Sep 15, 2010
  • 1 more comment
  • Jzeblaz Nov 03, 2010
    Got the same thing here. Tried unplugging for several minutes, osillating the temp. controls. No signs of life other than light coming on.
  • coachh101 Jul 12, 2011
    me too... what did u do?
  • donna foster Nov 24, 2012
    me too what next
Marvel 6BAR6004 not cooling
check you themoistat it may be coated with sofa
Jul 04, 2014 | Marvel 61WC Wine Cooler
Vinotemp wine cooler just stop working.
Ok check the power supply input. Assume you have do e that and all ok. More than likely it could be a thermostat or compressor gas leakage. Has the compressor been running more than usual before it gave up working. Check for rust on the internal coils as sometimes they fail. Depending on what you paid for the wine cooler it may be cheaper to simply replace it. Can highly recommend Delongi 145
litre bar fridge, after replacing several cheaper brands and it is very reliable and cools really well though they are not at the cheap end of the market. You get what you pay for with appliances. Best of luck resolving the problem but if the wine cooler no longer is getting cold but the compressor continues to run, you can bet that it's out if gas from a leak in the internal pipe work and generally not worth attempting to either locate and or repair.
Apr 28, 2014 | VinoTemp (VT60GNV) Wine Cooler
CWR531SZ EDGE STAR WINE COOLER FOGS
professionally installed or diy if pro call them back sounds like cooler is cold room to warm
Apr 12, 2013 | EdgeStar CWR531SZ - 53 Bottle Built-In...
Compressor seems bad
HI sally.well wine coolers r not rocket science.your local engineer should be able to at least diagnose the problem...lets c if u can do it ok?(still getting power )u mean light comes on or u mean it runs but dont get cold?well haier is not the best but if it's done 7 years is not bad:).ok...1-check if it makes any noise or is completely quiet.if no sound feel the motor (compressor).hot or cold.if cold it could be the thermostat or motor.if hot running or not it could be refrigerant or motor.needs visual.hope this helps.ALI
Jul 09, 2012 | Haier HVFM20ABB Wine Cooler
Have a CVKG581 Wine Cooler and it is not getting cold. Light goes on so I know power is getting to the cooler
HI,CHECK THE COOLER TEMP CONTRL ,CHECK THE COMPRESSOR AND CHECK THE EVAP MOTOR ,,ANY OF THIS COMPONENTS MAY BE BAD..GOOD LUCK..
Feb 21, 2011 | U-Line Wine Captain (2015WC) Wine Cooler
I have a Avanti wc492d wine cooler that is not working. The unit shows power(lights are working) but it will not cool at all. I can here a click sound when I change the temp set, but the cooler will not...
The issue could be the cold control, timer, wiring, or the compressor.
The temp control has to be closed for voltage to get to the timer. The timer then calls for the fans and compressor to run. The timer could have stalled after a defrost cycle or the cold control could not be sending voltage to the timer.
Jan 28, 2011 | Avanti WC492D Wine Cooler
Set temp to 42 and 54 but unit stays at 75. HELP!
sounds like the compressor is not running . ck the connectons at compressor and listen for a click in the cold control as it may be bad .. / noises like clicking at compresor . may be the relay that starts it .. mm
Aug 09, 2010 | Danby DWC283BLS Wine Cooler
I have a magic chef wine cooler model mcwc16mcg justs keeping clicking not cold anymore , can this be fixed
A clicking sound every few minutes usually means the compressor is going off on overload when trying to start. This could mean the start parts are bad, or the compressor went bad.
Nov 22, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Magic Chef MCWC30MCG not getting cold?
You need to replace the Ptc unit attached to the compressor. Go to REPAIR CLINIC.COM and order the following part. 1206838 Ptc relay. They also will show you were it is located and how to replace it. Compressor tanks very rarely go bad. It is an $11.00 dollar part
May 28, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
U-Line no longer cooling
This sounds like the thermostat is the problem. I wouldsuggest touching the compressor at the back of the unit to see if it is hot or cold. If it is hot then you have probably have power down to the compressor, if it is cold you could (if capable) bypass the thermostat to see if it kicks in. Hope this helps.
Aug 23, 2007 | U-Line 2075WC Wine Cooler
KitchenAid KUWA244PBS Wine Cooler Logo
419 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
