Question about Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER
17.5 hp MTD mower, model 13a608g062...question on changing the drive belt, can not get the engine pully off to get the belt out...this is the only problem in the whole procedure??? Thanks.
steveym
  • 11 Answers
SOURCE: i have a mtd 13.5 horse 38 inch cut 6 speed its
Most mower decks have the diagram on them, if not go to MTD.com and put your model number to see the diagram.
Posted on May 03, 2009
  • 376 Answers
SOURCE: MTD Lawn Tractor problem
The front belt should be a 954-0280A, rear 954-0370. When you go to higher gears, the front belt should be getting tighter as the vari-speed pulley is moving further back. Remove the shift plate, put the transmission in neutral. Start the engine, put speed selector in highest gear and slowly let out on the clutch. You should be able to see what the problem is. It will do everything the same as if were in gear, except move. Make sure you have the correct belts.
Posted on Jun 28, 2009
  • 12 Answers
SOURCE: Lawn tractor jerks when driving across lawn
Can you adjust tensioner
Posted on Jul 20, 2009
  • 61 Answers
SOURCE: lawn mower pull cord
This works best with two people. Remove cover and pull cord will be inside cover. If your handle on pull cord is attatched to a metal ring up on the handle, you will need 8 foot of new pull cord.
With all the old cord removed, wind cord pulley 6 revolunations, now, have someone hold the pulley, while you string the new cord thru pulley and out the cord hole on cover. Be sure to put a knot on the end going thru pulley. Draw cord all the way thru and out of the cover. Attatch the handle and let it rewind. You will have extra cord, this will be used up going from engine up the handle. I hope this helps
Posted on May 09, 2010
SOURCE: i have an MTD 3.5 hp Tecumseh lawn mower. The
WHAT KIND OF OIL DO I NEED FOR THE LAWN MOWER
Posted on May 14, 2010
What is the drive belt adjustment 11.5 hp ride on mower
The drive belt is tensioned by a spring on the clutch pedal. If you can give me the model of mower you are working on, I can help you find the spring or the variable speed pully.
Thanks, Matt
Jan 15, 2011 | Mtd Garden
Adjust the drive belts,
if you have the belt installed correctly, the idler pully is the only adjustment and thats automatic. i trust you have installed the correct belt.
Apr 29, 2010 | Garden
I need help fitting the blade belt to my MTD RH125/92 can you help i cant find the manual anywhere
This can be a tricky job. There is two 180 degree twists when fitting the belt. Viewing the deck from behiend, looking toward the front, run the belt coming from the engine around the left blade pully. Twist the belt 180 and run it at an angle to the front of the right blade pully, this is to drive the blades in opposite directions. Coming off the back of the right pully go around the tensioner pully and between the tensioner and the engine pully make another 180 degree twist. I have fitted a few of these and i have a diagram here in front of me but i cant find a way to show it to you. Hope this helps. Stephen.
Sep 14, 2009 | Mtd Garden
MTD 12-38 Shifting problem
mtd 12/38 blads not stoping ? theres a ajustment rod on right side under the mower turn clockwise to losen belt .
Jul 09, 2009 | Mtd Garden
John deere mower won't engage
on the engine there is a shaft with 2 pullys ,drive belt goes to the top closet to the engine lower pully is for the deck
there also is a saftey switch located on the deck which should shut down blade operation when raised. check the mandrels for broken bearings by grabbing the pully and wiggle them back and forth looking for movement could be possible that one madrel is shot giving you that bad sound which is crushed bearings
Jun 30, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
I need to replace two belts on mtd mower i have no manual
im guessing your question is about the diagram for the direction of belts and which pullys they go on?
i would google it.
google the qeustion but in qeustion somwhere state that you need the belt diagram 1)engine drive belt
2) mower deck drive belt
Jun 24, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER Logo
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
