Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp AR-5316 I have an error message H-4 flashing on our display. Can you tell me how to do?
The code sequence in above solution is for old sharp models but for this model please enter the sequence # , interrupt , C, interrupt. and then enter 1 , 4 . then press start button
Posted on May 15, 2008
Enter the following code.
cancel -- interupt -- zero -- interupt - the display should switch off then enter 14 and push the copy button- copier should reset if not heater lamp could be blown
Posted on May 12, 2008
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems Posted on Aug 16, 2016 -2017
Jul 29, 2016 | Sharp Ar 5316
I have a sharp photocopier AR-5316 flashing error code is h4 how to reset this code and solve the problem
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
Jul 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-5316 errors
heat roller low temperature direction
Jun 24, 2010 | Sharp AR-5316 Advanced Digital Imager...
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
May 12, 2008 | Sharp AR-5316 Advanced Digital Imager...
Request service manual for sharp AR-5316
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=7b292ec58f421b3b3b442c1437984770&q=Sharp+AR-5316
Apr 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
Ar-5316 L 4
On this model there is a mirror lock for the scanner section, its found underneath the top left hand side were the paper exits, it gets moved to the lock position by accident.
Mar 17, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Jan 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
97 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
