Question about HP Deskjet F340 All-In-One Printer
Can you use the HP 27 Ink Cartridge with the HP Deskjet F340?
  • HP Master
  • 4,737 Answers
No you cannot use Cartridge 27 with Hp Deskjet F340 printer. The printer only supports, 21 (black), 22 (color) and 58 (photo). I hope this clears your doubt.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Sep 04, 2010
What is an OEM cartridge?
OEM (pronounced as separate letters) is short for original equipment manufacturer
The Cartridges for the HP DeskJet 3740 InkJet Printer are:
HP 27 Black Original Ink Cartridge
HP 28 Tri-color Original Ink Cartridge
These can be purchased from your local store that sells HP Printers & ink or by going to HP.com and ordereing direct from the Manufacturer
May 01, 2014 | HP DeskJet 3740 InkJet Printer
How do i clean ink heads on hp deskjet f340 all-in-one
Things to clean:1. Little warm water & bowl2. tissue paper3. Ear budsDip cartridge nozzle part in water, wait 10 seconds, take out & swab nozzles with ear buds, clean with tissue paper as shown in fig.. check for the print quality.. repeat two or three times if required.. if no recovery better to replace the cartridge.. 4_29_2012_9_45_00_am.jpg4_29_2012_9_45_32_am.jpg4_29_2012_9_46_04_am.jpg
Apr 28, 2012 | HP Deskjet F340 All-In-One Printer
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    I am unable to locate ink cartridges in HP Deskjet F340; where the heck are they? I have replacements to install. I know this sounds really stupid!
    Go to this help page for instructions:
    F300 Series Ink Replacement
    You may also be interested to have the main support page for your printer:
    F340 Support
    Add it to your favorites. It may come in handy.
    Thanks for using Fixya. Please take a moment to rate this solution.
    Feb 06, 2010 | HP Deskjet F340 All-In-One Printer
    How do I refill the HP F340 cartridge? Thanks.
    Are you using a factory new ink cartridge?
    Please consider the following:
    If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
    They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
    If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
    Don
    Nov 18, 2009 | HP Deskjet F340 All-In-One InkJet Printer
    Problem printing photos
    When printing a photo make sure that your quality is set on best and not normal.
    Also check the ink level on your colour and black cartridges and make sure it is sufficient.
    Last but not least if you are using remanufactured or refilled cartridges this is a common problem. The cartridges are not made for the printer or they have been refilled and they now have blocked printheads and the ink is doing interesting things. If you buy a real hp cartridge and it should clear the issue up.
    Dec 16, 2007 | HP Deskjet F340 All-In-One Printer
    109 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
