Question about Hoover S3765-040 WindTunnel Bagless Canister Vacuum
Hoover S3765-040 vacuum cleaner. At high motor speed, starts to smell something burning. Opened the motor assembly; removed the motor from its housing; powered it; and see major sparking where the bushings touch the motor. Does this mean the motor is toast? Can I buy a new motor? It says the motor is LG UMC400L2 120V 60Hz 060522-D Made in Korea. There is also a black foam covering around the motor which is full of dirt and hair and is messed up. Does that come with the motor? Thanks
  • Hoover Expert
  • 357 Answers
You are correct, the motor is done. Look at your local vac store for a quality vacuum made by Sebo or Miele. Replacing motors in chinese made vacs is a waste of money as the whole product was made to last only a couple of years
Posted on Jun 12, 2017
  • 1673 Answers
SOURCE: Hoover windtunnel will NOT turn on
You have to remove the motor cover, There I believe 5 screw, take off the light lens and remove the screw holding the light. It should then pull off. You say you have power to the Vac, but do you have power to the motor. There also is a thermo by the motor, sometimes they open up, then the motor won't run.
Posted on Jan 06, 2008
  • 126 Answers
SOURCE: Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Posted on Jan 27, 2008
SOURCE: How do I change the belt in a Hoover U4262-930
You got the second hardest part done; the hardest part is what you're asking about.
To get the new belt onto the drive shaft I used a long screwdriver for leverage and wrapped the end close to the shaft and with some elbow grease, got it to "slip" on to the shaft. It took a couple of tries, but once I overcame the fear of the belt breaking (because it has to stretch big time), I managed to get it one. Of course, the other end of the belt has to be wrapped around the roller first.
I found a link for a tech manual for this model, but it didn't help much....
good luck.
Posted on Apr 24, 2009
SOURCE: high pitch
The Hoover Fusion has design flaws in the motor, including a metal plate that is too thin to contain the forces acting on the motor, particularly the constant strong tension from the drive belt, and a plastic plate that is attached to the metal plate by two screws that gradually loosen over time. Assuming the filters and canister are clean, a high-pitched noise coming from the motor indicates it is about to fail as a result of these problems. You can replace the motor after it fails, but the problem will eventually occur again. For those very mechanically inclined, when the motor first starts making the high-pitched noise, you can dismantle it and tighten all screws.
Posted on Jul 10, 2009
  • 97 Answers
SOURCE: Hoover Vacuum Cleaner Bad Smell
change filters. the filter inside the unit and the one on the side needs to be changed once a yr. (these are not to be washed, only the side filter if foam can be washed ). also flat belt change every 6 months and the v-belt once a yr.
Posted on Jul 19, 2009
My hoover steam vac is making a horrible noise and smells like its burning
Something may have jammed the brush roller, preventing rotation. This causes the motor shaft to rotate in one spot on the belt, causing the burning rubber smell. Eventually, the belt will break. You need to find what caused the jam and remove it. It would be a good idea to replace the belt as a burned belt is unlikely to last much longer.
Dec 18, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Why Won't Hoover start and a burning smell
The motor is most likely burned out. Probably cost $100 to fix
Aug 27, 2014 | Dyson DC-33 MultiFloor Upright Vacuum...
I have a steam vac spinscrub carpet cleaner works good but it just started smelling like it was burning and started to smoke
Anytime someone says they smell something burning on any type of vacuum cleaner of carpet cleaner etc. All I can think of is the belt is rubbing on plastic which would cause the sense of something burning because you possibly are smelling the belt........
Mar 12, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hoover carpet cleaning started to smell like it's burning and black chunks of rubber came out
Nan, there's obviously a belt that's shot and needs to be replaced. If it started to smell, then it was probably bound up at some point in it's travel path, that stops it from running and the motor shaft burns it's way through the belt, making the smell.
Nov 03, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover canister vacuum (windtunnel)- turned it on and it had good suction, then smoke came out and it smells like something is burning. Is it the motor burning up or something else?
Probably the belt..
Turn it over so the bottom is facing up..
Remove the plate that surounds the brush..
Check to se if brush is spinning frely and that the belt is on there poroper
Jul 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
My Hoover bagless vacuum starts to smell like something's burning
What does it smell like? If it smells like burnt anything-it could be that the fan is broken and lodged in the motor. You can see if the fan is good just by looking into it.
Mar 13, 2009 | Hoover U5753-900 WindTunnel Bagless...
Burned smell
If the motor slowed down this would indicate a bad motor. not cost effective on this model to replace unless under warranty. it is not uncommon these days to see a motor go bad every now and then.
What are the first 4 digits of your serial number? this would be the month and year of mfr. even without a receipt, a warranty service shop should be able to assist you.
Oct 21, 2008 | Hoover U5507900 Elite Rewind Bagless...
Drive went out on my Hoover Steam Vac Shampooer and brushes won't turn plus there's a burning smell coming from it. Only used it 6 times - bought it in March - 2008.
Generic problem for all Vacuums
Posted by buster_lls on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me like you have multiple problems with your power drive; a burning smell and the brushes don’t turn, and the dop is on March, 2008 – the Hoover Steam Vac Shampooer has a one year factory warranty and it could be a broken part for the brushes won’t turn or a belt would cause the burning smell. If it is not the belt or broken part it probably is the motor of which you should take it to a authorized Hoover vacuum cleaner dealer in your area or to contact the Hoover factory cust serv listed below or the Hoover website for information. If it is the motor the factory authorized dealer will replace the part for the motor and the broken part for the brushes, if it is the belt that would be an out of pocket expense. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Hoover S3765-040 WindTunnel Bagless Canister Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
