Question about RCA CDRW120 2-Disc CD Recorder
I GET AN ERROR 6 MESSAFGE AND NEITHER TRAY A OR B WILL OPEN
Green light flashes 7 times
LED Blinking in Orange/Green:
2 times: No paper. (ASF) [1000]; Set the paper in the ASF, and press the Resume/Cancel button.No CD-R tray. [1001]*1; Set the CD-R tray, and press the Resume/Cancel button.
No paper in the cassette. [1003]; Set the paper in the cassette, and press the Resume/Cancel button.
3 times: Paper jam. [1300]; Remove the jammed paper, and press the Resume/Cancel button.
Paper jam in the under guide. [1304]
Paper jam in the rear guide.[1303]
Front door closed. [1250]; Open the paper output tray.
4 times: No ink.[1601 / 1611 / 1612 / 1613]; Replace the empty ink tank(s), or press the Resume/Cancel button. Pressing the Resume/Cancelbutton will exit the error without ink tank replacement, however, ink may run out during printing.
5 times: The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 /1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on.
6 times: Inner cover open. [1841]*2; Close the inner cover, and press the Resume/Cancel button.
Inner cover open (during printing on paper). [1846]*2; Close the inner cover, and press the Resume/Cancel button.
CD-R tray guide closed (during CD-R printing).[1850 / 1855]*1; Open the CD-R tray guide, set the
CD-R tray properly, and press the Resume/Cancel button.
CD-R tray guide open (during printing to paper). [1851 /1856]*1; Close the CD-R tray guide, and press the Resume/Cancel button.
7 times:No CD-R or DVD-R. [1002] After setting a CD-R or DVD-R in the tray, set the tray in the tray guide, and press the Resume/Cancel button.
8 times: Warning: The waste ink absorber becomes almost full (approx. 95% of the maximum capacity). [1700]; Pressing the Resume/Cancel button will exit the error, and enable printing. The service call error, indicating the waste ink absorber is full, is likely to occur soon.
In repair servicing, replace the bottom case unit (QM2-1249), or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864).
9 times: The connected digital camera or digital video camera does not support Camera Direct Printing. [2001]; After removing the cable between the camera and the printer, press the Resume/Cancel button, and
re-connect the cable.
10 times: Automatic duplex printing cannot be performed (paper size not supported). [1310]; Press the Resume/Cancel button to eject the paper being used at error occurrence. Printing will resume from on the front side of the next page.
11 times: Failed in automatic print head alignment. [2500]; Press the Resume/Cancel button, and after confirming the following, perform print head alignment again: - Set an appropriate type and size of paper (plain paper, A4 or letter). - Check that the nozzle check pattern is properly printed (all ink ejected, no faint printing). - Protect the paper output slot from exposure to excessive light.
Access cover open. [1200]; Close the access cover.
LED Blinking in Orange and Green Alternately, or Lit in Orange:
2 times: Carriage error [5100]
3 times: Paper feed error [6000]
4 times: Purge unit error [5C00]
5 times: ASF (cam) sensor error [5700]
6 times: Internal temperature error [5400]
7 times: Waste ink absorber full [5B00]
8 times: Print head temperature rise error [5200]
9 times: EEPROM error [6800]
11 times: Carriage lift mechanism error [5110]
12 times: AP position error [6A00]
13 times: Paper feed position error [6B00]
14 times: Paper feed cam sensor error [6B10]
15 times: USB Host VBUS overcurrent [9000]
16 times: Valve sensor error [6C00]
17 times: Motor driver error [6D00]
20 times: Other hardware error [6500]
Continuous alternate blinking: rom error
Aug 31, 2014 | Canon PIXMA iP2000
My canon pixma ip2000 lights flashing 7 times
LED Blinking in Orange:
The messafge "ArcSoft Connect Daemon
Start> Run> (type in) msconfig > Startup tab> uncheck the ArcSoft program> Restart.
Plan B... Look over the programs at http://www.arcsoft.com/en-us/index.asp
Check Add or remove programs for any of those programs and uninstall the program or turn off
automatic updates or connect automatically or whatever similar feature you find.
Hope this helps,
Aaron
Jun 05, 2011 | Arcsoft Computers & Internet
How do I enable this player to become multi-region? I believe it's based on a Pioneer rather than one of Teac's own designs.
Hi
Thanks for using FixYa. To make it multiregional please follow these step by step instructions using your remote control:
1. Switch power on
2. Open the DVD tray (leave it open with no DVD in it)
3. Press "stop"
4. Press "734466"
5. Use cursor to scroll up or down until it says "Region 0"
6. Press "OK/Enter"
7. Switch power off
8. Switch power on
It show now play all region DVD’s. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 30, 2010 | Teac DV-H500 DVD Player
Brand new 360 elite will not play nba live 09 ONLY
ok , if it is giving u the open tay error , every time u try and load it , it could be a number of reasons behind it , i had the same problom , most games will play but i had 1 game that no matter how many new copys of the game i got , when i put it in my xbox the game spun 3 times and then said , open tray , like trhere was no game in the xbox, so i went 2 you tube and typed in open tray error xbox 360 and there r loads of examples on how 2 fix it , if u keep opening and closing the tray each time after it says open tray after about 6 to 7 times , it should play , but i would go 2 you tube , becase u need 2 open your disc drive 2 fix the problom.
Jan 13, 2010 | Microsoft Xbox Console
Want to play my old DVDs from overseas, but I get a region code error.
Try the following:
1. Open tray and remove any disks in tray.
2. Close tray.
3. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM)
4. Reconnect to mains
5. Turn on player with remote.
6. Press ENTER on remote.
7. Press 8, 4, 2, 6, 9. Using keys on remote. If your player is already set to region 2
8. Press ENTER on remote. (The tray will open and player will power off and close tray.)
9. Switch on power from remote.
Player is now Region Free.
Apr 16, 2009 | Samsung HT-DS610 System
Xbox 360 open tray error
How I worked around the "Open Tray" problem, where the game discs were not being recognized:
1. Open tray
2. Unplug power cable while tray is open
3. Plug in power cable
4. Power on console - tray closes
5. Open tray
6. Insert disc
7. Try your game
Good luck! Source: Someone else mentioned this in a forum somewhere, however I don't recall who it was or which forum. I'm just trying to get the word out so people don't send in their XBOX for repair, or open the case and void the warranty if this workaround resolves the problem.
Mar 25, 2008 | Microsoft Xbox 360 Console
Turn off card protection
The SD card has a small "lock" slide switch on its side. Simply slide it away from the contacts edge.
Saul.
Jan 11, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Cd doors don't open and Errors 1 and 4
I had the same problem with my CMT-EP707. I read on this site to try various combinations of turning power off then turning the power back on while holding down either or both of the stop play button and the eject button for the affected CD tray. What seemed to work for me was turning on the power while holding down the eject button for CD tray 2, even though the error referred to CD tray 1.
Jan 02, 2008 | Sony CMT-EP707 CD Shelf System
Drive wont open/eject
try, go to my computer>properties>hardware tab>device manager and go down the list to cd/dvd drives, click on the '+' and right click on your listed drive and select uninstall. restart the notebook and then the drive will be re installed with drivers automatically. it may be a firmware or driver error.
Apr 17, 2007 | LG GSA 4163B DVD±RW Dual Layer Burner
RCA CDRW120 2-Disc CD Recorder Logo
41 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
