Question about Maytag 18.6 Cu. Ft. Bottom-Mount Refrigerator - Black
The freezer is cold but main refer is not. why?
U need to change the dryer and fill and gas only
Posted on Jan 04, 2012
  • Maytag Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 05, 2010
Samsung model RB1844SW. Refrigerator and freezer stop cooling. Unplugging and plugging back in resets and it works fine for 7-8 hours before the same problem occurs.
Check if the circulation motor /fan which blows air around the inside is working . It is located near the top of the refer. also check if air is circulating in the freezer there is a main fan in there which sends cold air from the freezer to the refer. If either fan wears out sometimes it runs for a while and sometimes not. the motor chatters sometimes before it dies. I have had defroster control timers go bad, causing this problem too, because the refer goes into defrost cycle and doesn't go back to refrigerate mode till the defrost cycle is over. if the timer clock stops it will do the same thing, and not go in to refer mode. Good luck, Bill
Jan 07, 2018 | Samsung Microwave Ovens
Zis480mnc ge monogram built in refer temp varies from 34 to 48 several times a day.
Try replacing that evap thermistor. The diagnostics on thermistors can be wrong. If it is rounded on the end, replace it. There is a damper between the freezer and refrigerator. There may be a refrigerator fan motor in the damper assembly, It could be bad. It could be a bad control board. When you run diagnostics there is one function that checks all the fans.
Sep 25, 2014 | Refrigerators
A kenmore side by side model 106 5661 2500 has warm refer and cold freezer
If the freezer temps are normal and the refrigerator is warmer than normal, the the air flow from freezer to refrigerator is being hampered either by ice on the evaporator or the freezer is stuff in such a way that normal airflow between freezer and fridge is hampered. If the auto defrost is not working properly you will have warmer freezer temps and a relatively warm refridge. Check the defrost timer and defrost heater element.
Nov 26, 2013 | Kenmore 56612 Side by Side Refrigerator
I have an amana ASD2626hes side by side refer/freezer unti. REcently it soppted colling in the refer and the freezer was cold on the bottom only - top warm. I pulled the freezer inside coer - found the...
It could be either....
It is best to check and see if you are getting power to the fan...power to fan, the fan is bad...no power the board is bad...
heatman101
Apr 23, 2011 | Amana Refrigerators
Maytag model #mtf 2156ge freezer is good and cold,everything still frozen, bottom is not cooling
check to make sure the shutter between the freezer and refrigerator section is operating. The shutter has a small motor that opens and closes on the refer side thermostat. The shutter is what lets the cold air from the freezer circulate into the refer compartment. Could also be a bad thermostat in the refer section.
Dec 29, 2010 | Refrigerators
Freezer freezes, refer warm?
That must be a defrost problem. I would bet the defrost heater has failed. The evaporator is all clogged with ice and the cold air to the top is non exsistant. You need to access the evaporator and check for ice. A good symptom is frost on the back side. NOTE: you can remove the control panel cover and check the heater from the main board by removing the plug and checking for continuity.
Jan 23, 2010 | Kenmore 24.8 cu. ft. Trio French Door...
Whirlpool ET20GK top freezer works ok bottom refrigerator does not cool. I defrosted, the two air passages from top to bottom are open. The fan in the freezer is running .Is there another fan? I vacuumed...
make sure you air damper in the refer section is open
and allowing cold air from the freezer in to refer section, close the freezer door and make sure you can feel the cold air dumping in
its good thaty you cleared the two air passages
but something may be clogging your air diffuser
Oct 26, 2009 | Refrigerators
Freezer is cold but refrigerator is hot. Fans are working.
your refer is 100 % dependendent on the freezer,
the first thing i would suggest is to check your airflow,
if your fnas are working, are the drawing air off a clear evap coil, is there extra frost in the freezer,
can you feel cold air comming into the refer from the freezer,
on all units there is a damper of some sort, and a return the air is cycled through those and the evaporator.
check these things
Oct 12, 2009 | Refrigerators
Freezer compartment on refrigerator not cold enough
depending on the temp it could
if the ambient temp get below 32
you freezer wont come on and actually begin to get warm (insulation factor)
but the refer will seem cold because of the low ambiant temp is the temp inside
we go in the refer alot more than the freezer
Mar 28, 2009 | Frigidaire FRT21S6A Top Freezer...
Maytag 18.6 Cu. Ft. Bottom-Mount Refrigerator - Black Logo
71 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
