Question about Imperial IFS40 Deep Fryer
End way inition flame dont started
  • Anonymous Jun 16, 2008
    pilet
  • tezrez Jun 16, 2008
    pilet light will not stay on
    Problem Solver:
  • 10 Answers
Check the milli volt it must be around 500 .if it is check the solenoid
heat the pilot and check it
good luke
hamid
Posted on Aug 14, 2008
Ignition will not stop clicking
do you have to press a button to ignite? water has in.
If it is in the oven then its different. The igniter is always trying to light the oven when the oven is on. You dont get a spark because the flame conducts electricity. if there is no flame, then you get a spark which lights the gas again (Clever init). So you either have a bit of dirt which is stoping the flame going between the two electrodes or the electrodes have got knocked and are not in the flame.
Jun 16, 2014 | Premier EAK600BP Stainless Steel Range
Pilot light goes out when you relase the gas controll valvue
your gas heater needs cleaning
you can do it yourself
shut gas off to heater
disconect line going to pilot
and the other end into valve
get a straw and blow into line and where it conects
also use vacuume on the end where pilot flame comes out
clean the end of thermcouple( where flame hits)
put it back together BE SURE CONECTIONS ARE TIGHT
dont want gas leaks
Oct 10, 2013 | Williams (5009622) Ceramic Gas Wall...
Water heater flame problem
Check your exhaust, see if its clogged or blocked, clean the flame sensors, I that does not work, then your gas valve is starting to go bad, there is a cap on it if you take the cap off you can turn the gas flow down a little bit,
Jul 14, 2013 | RTO Atwood Water Heater - 6 Gal LP
My Ruud achhiever 90 starts to fire but as soon as the blower fires the burner goew out. I also noticed that the "igniter" on the end isnt firing. Could that cause the burner to not stay lit when the
There is an ignitor and a flame sensor. If the ignitor does not ignite the gas after a time, it goes out. If the flame sensor does not detect ignition the gas valve closes. When you start it you should see the ignitor come on like a light bulb and glow, then the gas valve opens and you get ignition. Then the flame detector turns on when the ignitor goes out. Flame detectors are like a chrome wire that has one connection to it and it sits part of the way in a burner. They get dirty and corroded. When that happens it shuts down. You can clean the flame detector with steel wool of scotch brite pads. Dont get too carried away doing that though.
Dec 25, 2012 | Heating & Cooling
Ge cooktop jgp636 : water leaked onto the igniter switch. It started to click, click. Finally there was a spark, and flame,under 2 of the 5 switches. Then when I tried turning on one of the unaffected...
you might have shorted out the switch which caused it to burn...you can change all the switches buy ordering from searspartsdirect.com put in Model # and search switch...you probably gonna need some serious wiring..i recommend call the tech
Oct 27, 2009 | GE Profile JGP636 Gas Cooktop
Sony vegas crashesat Initalizing UI
I had this problem once and it was after I tried to fix my registry with one fix all software utilities. In the end I actually had to re-install my operation system. There probably is a better solution, but that one was the one that worked for me.
May 03, 2009 | Sony Vegas Pro 8 for PC (SVDVD8006)
Audacity sound ubuntu
Your command is slightly flawed. Try again as follows, making sure to include all spaces (copy and paste the command if it'll help)
sudo /etc/init.d/alsa-utils start
Note the space between sudo and /etc/blahblah and the space between /etc/blahblah and start. Also note the occlusion of the second L to the end of the alsa-utils command.
Hope this helps,
SlaeYer
Aug 03, 2008 | Canonical Ltd. Ubuntu
Acer aspire 5920 N
just turn it on it will boot through linux u will get the user login put root or username if created and password for that then it will go to graphical mode if u wan to shut down u will be having a option there only if there is no option just open terminal type init 0 command
init with Zero command or else say halt
Jul 22, 2008 | Acer Aspire 5920-6574 Notebook
Flame
put a pair of plairs on this will over ride the thermostst meaning u need a new one
May 10, 2008 | Imperial IFS40 Deep Fryer
Gas Kitchen Oven ignition
sopunds like a little to much gas is being released upon first inital start up, then igniting extra gas causing the "puff", i might check the oven bar under the oven floor, perhaps the little holes in the burner bar have become clogged . ofthe electrode is a little to far from the bar try twisting just a little bit closer(careful thougfh you dont wanna break it)
Apr 07, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Imperial IFS40 Deep Fryer Logo
29 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
