Question about KitchenAid Dishwashers
HOW OFTEN DO I NEED TO RUN MY DISHWASHER? - KitchenAid Dishwashers
  • KitchenAid Master
  • 43,501 Answers
To keep it runnin good and not smeeling at least a couple times a week...
heatman101
Posted on Sep 07, 2010
How much vinegar do you add to the dishwasher?
For regular monthly maintenance fill the dishwasher soap dish with vinegar once a month and run a regular cycle with an empty dishwasher. If you're having problems with dishes not getting clean or dishwasher soap build up on the floor of your dishwasher do the above now. You may need to run the empty dishwasher with vinegar a few times to clean the drain lines; running empty once a week with vinegar is not too often.
Oct 30, 2016 | Dishwashers
FIRGIDAIRE DISHWASHER FDB1050RES0 WASHING LIGHT BLINKING CONSTANTLY BUT MACHINE WON'T RUN
Thank you for your inquiry, William Garrett!
I understand that the washing light on your Frigidaire dishwasher, FDB1050RES0, continues to blink and will not run. You may need to perform a reset on your dishwasher. In order to do so you would need to disconnect power from your dishwasher for roughly ten minutes. This will help clear out any false error codes or miscommunications within your dishwasher. If resetting your dishwasher does not resolve the issue you may need to have an electrical component replaced and I would recommend seeking professional assistance for that. Hope this is helpful. -Matt
Feb 16, 2015 | Frigidaire Dishwashers
DISHWASHER was locked now unlocked but won't run. Goes to drain/Cancel when you push the Normal Cycles
Wondering how you unlocked the dishwasher. Normally you would have pressed Heat Dry for about 4 secs.
I don't this action would have caused the problem. For dishwasher to run you need the door lock switch to operate. If door is not closed it will go to Cancel.
Check item 12 in this diagram.
Oct 26, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
It sometimes run water on to floor . the drain is not kinked.
first of all, you must check to make sure that the door is closing properly before you run it, and that nothing is sticking out, or trailing out of the door.
secondly you must never open the door during the running of the dishwasher.
check to make sure the drainage is clear of protrusions. use special dishwasher cleaning salt if you need to. to do that, you need to obtain the special salt and run the dishwasher empty, it cleans away all the junk blocking the drain.
additionally, the connections to and from your dishwasher could be faulty and or leaking. check the input and output water line connections on the dishwasher and their other ends as well.
Mar 26, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Ther's a foul smell coming from the dishwasher evert time I open it. Doing a wash does not solve this. I'v had this since it was new, months ago, and have had the installer look at it, said it wasn't his...
You need to run a cycle with a dishwasher cleaner inside, you can get these from the same place you get your dishwasher powder from, Before you run the cleaner through remove the filters from the bottom of the machine and place these in the rack, run through the hottest cycle with these filters in the racks and the dishwasher cleaner in place, this will clean the dishwasher properly and assist with correct draining and the odour, if the dishwasher is sitting for long periods unused leave the door open slightly to allow it to dry out.
May 13, 2017 | Frigidaire FGHD2433K 24 in Builtin...
My dishwasher is not cleaning my dishes the inside of my dishwasher is thick with white residue
hello. I can help you. Make sure your dishwasher is empty. Then pour two cups of vinegar into the dishwasher. Next run the hot water into your kitchen sink until it is as hot as it gets and start your machine. Run it on the longest and hottest cycle you have..
This will clean your machine. Repeat the process with more vinegar if you need to.
Once your machine is clean, be sure to always run your sink water until it is hot before turning on the dishwasher and also rinse your dishes. good luck with it.
Sep 13, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Dishwasher is leaving white film on dishes. I have handwashed and when I dry the dishes the film is back. Please help I want to scream. Do I need to buy new dishwasher?????
just relax all you need to do is run a few load with tang brakfast drink run fauset till you get hot water put about a cup in the bottom and fill soap cup with tang you may run dishes with the tang NO SILVER JUST PLATETS AND GLASSES
Jun 20, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Not cleaning dishes
For starters run the dishwasher through its entire cycle empty and add only one cup of vinegar. This will clean and disinfect. Next run the dishwasher through a second full cycle with nothing but water. This may be all you need to do to get your dishwasher back up and running.
Apr 30, 2009 | Dishwashers
Dishwasher runs for 3 hours
Are you using the high wash temp setting? I was having the same problem with my dishwasher while using that setting. Apparently, it will run until the temp gets to its required number. And my hot water heater was set to not go that far. So my dishwasher would run and run. I fixed it by not using that setting any more.
Aug 14, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
GE GSD2200G02CC dishwasher
Your dishwasher probably has rotating blades on the top and bottom that spray water on the dishes.  Clean these off and make sure the holes are not clogged.
Sep 14, 2006 | GE GSD2200Z Dishwasher
Dishwashers Logo
35 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
